[Live-demo] disc space
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Aug 1 10:36:45 PDT 2013
I think that the problem is that tmp disk space is also included in each
step.
So if an application downloads much data in /tmp and does not clean up
(because the setdown.sh will clean /tmp at  the end), the size goes up.
Remember we do a df in chroot so we get all the host filesystem info (the
build server does not do anything else during build)
Perhaps a du -sk /tmp before and after each package installation would help
determine how much data are actually installed (/tmp excluded)
On Thu, Aug 1, 2013 at 8:11 PM, <maplabs at light42.com> wrote:
> On 1 Aug 2013 13:04:18 -0400, Stefan Steiniger <sstein at geo.uzh.ch> wrote:
> Hi,
>> so I see that Kosmo takes a lot of space (600+MB).
> I am looking at this chart, too. I see Kosmo taking 143M on disk, in
> /usr/lib/Kosmo-3.0
> I think this chart has some kind of basic problem.. this makes no sense to
> me.. more when I get the 560 build
>   -Brian
>  > Wonder why - if the core of Kosmo was actually taken from JUMP GIS
>> (12MB) (look at the size of OpenJUMP: < 100MB). So maybe they use lots of
>> libraries for being able to read certain file types (gdal? mrsid/ecw-raster
>> drivers? ), and each different per OS (win vs Linux vs MacOsx). Or do they
>> have included lots of data.
>> So, it is somehow surprising when seeing disk space use if Komso in
>> comparison to gvSIG and OpenJUMP.
>> cheers,
>> stefan
>> Am 01.08.13 08:09, schrieb Hamish:
>> > Hi,
>> > Hamish wrote:
>> >>   I will work up a new usage chart for tomorrow's meeting. >
>> > caveats/notes as these disk space results are not definitive:
>> >   - OSSIM is missing in this build
>> >   - the first of e.g. grass or qgis to run will install many of the
>> other's dependency packages, so will unjustly seem larger/slower. >   -
>> /tmp usage is included here, but not on the disc. so some may be up to
>> doubled. >   - probably some other misleading/confounding variables in it
>> > but it's good for a general idea of what's going on. So to the plots---
>> > Disk space used by each install script as a time-series, sorted
>> > by biggest hog first, and a whisker plot of the distribution:
>> > http://muck.otago.ac.nz/~**hamish/osgeo/disk_usage_**timeseries.png<http://muck.otago.ac.nz/~hamish/osgeo/disk_usage_timeseries.png>
>> > http://muck.otago.ac.nz/~**hamish/osgeo/disk_usage_**sorted.png<http://muck.otago.ac.nz/~hamish/osgeo/disk_usage_sorted.png>
>> > http://muck.otago.ac.nz/~**hamish/osgeo/disk_usage_**whisker.png<http://muck.otago.ac.nz/~hamish/osgeo/disk_usage_whisker.png>
>> > Time used by each install script as a time-series, sorted
>> > by longest running first, and a whisker plot of the distribution:
>> > http://muck.otago.ac.nz/~**hamish/osgeo/time_to_install_**
>> timeseries.png<http://muck.otago.ac.nz/~hamish/osgeo/time_to_install_timeseries.png>
>> > http://muck.otago.ac.nz/~**hamish/osgeo/time_to_install_**sorted.png<http://muck.otago.ac.nz/~hamish/osgeo/time_to_install_sorted.png>
>> > http://muck.otago.ac.nz/~**hamish/osgeo/install_time_**whisker.png<http://muck.otago.ac.nz/~hamish/osgeo/install_time_whisker.png>
>> > (suggest 'make -j 4' or so might be help for the compiles)
>> > have at it,
>> > Hamish
>> > ______________________________**_________________
>> > Live-demo mailing list
>> > Live-demo at lists.osgeo.org
>> > http://lists.osgeo.org/**mailman/listinfo/live-demo<http://lists.osgeo.org/mailman/listinfo/live-demo>
>> > http://live.osgeo.org
>> > http://wiki.osgeo.org/wiki/**Live_GIS_Disc<http://wiki.osgeo.org/wiki/Live_GIS_Disc>
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130801/0ca9cd38/attachment.html>
More information about the Live-demo mailing list
