[Live-demo] [OSGeo] #1188: geoserver: server errors in cartaro and geonode
OSGeo
trac_osgeo at osgeo.org
Fri Aug 2 19:05:29 PDT 2013
Reporter: hamish | Owner: live-demo@…
Type: defect | Status: new
Priority: minor | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: geoserver, cartaro, geonode
Comment(by hamish):
Replying to [comment:4 hamish]:
> > having lots of noisy false errors in the build logs makes the
> > real errors harder to spot. so it is best to quieten them if we can.
Replying to [comment:5 kalxas]:
> (In [10592]) trying to make geoserver startup and shutdown silent
(refs#1188)
I should have added that simply redirecting everything to /dev/null is not
good either, because then you end up hiding real/important errors, and so
make debugging harder.
it's better to go in and find the exact lines in the scripts being noisy,
and add --quiet as needed, or just redirect stdout to /dev/null if that is
where the noise is coming from, and leave stderr passing through.
same for the half-megabyte of rasdaman pgsql noise in the build log, but I
don't understand why "-q" doesn't work there. Is there a "NOT QUIET;" or
so in the db.sql command file or something?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1188#comment:6>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
