[Live-demo] [OSGeo] #1159: ossim blocks nightly builds
OSGeo
trac_osgeo at osgeo.org
Mon Aug 5 11:13:02 PDT 2013
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: major | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: ossim, libgdal
Comment(by kalxas):
it seems that there is a change in the build message:
Processing triggers for menu ...
Reading package lists...
Building dependency tree...
Reading state information...
libgdal1h is already the newest version.
libgdal1h set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libgdal1-1.10.0-grass : Depends: grass643-3 but it is not installable
E: Unable to correct problems, you have held broken packages.
ERROR: Package install failed! Aborting.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1159#comment:16>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
