[Live-demo] Emailing: GdalTools.zip
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Aug 16 07:38:54 PDT 2013
Hi Micha,
Thanks for the patch and for testing. I believe that this can be used for
fixing 7.0 build but not for packaging (upstream).
I am also waiting for Jerome to complete a test with the qgis package
before I apply your patch.
Best,
Angelos
On Fri, Aug 16, 2013 at 12:30 PM, Micha Silver <micha at arava.co.il> wrote:
>  After some testing this morning, I was not able to just add the
> versionNum() function to the GdalTools plugin. There are apparently other
> API changes in the 2.0 plugin that would need some additional backporting.
> So I tried instead Hamish's hack of just sticking in version "1.0.0"
> everywhere to fool the plugin. That seems to work fine. A quick test in a
> VM of last night's build showed that all the Raster menu items re-appear,
> and I ran two tools (that had disappeared) successfully.
> Having said that, I'm not really comfortable with this. It circumvents a
> test that *should* be in place. Even tho' there's zero chance of Ubuntu
> reverting back to gdal < 1.8. Any other opinions?
> Attached is a zip with the required patch files to the various GdalTools
> python scripts to get the menu working again.
> @ Jerome: Do you consider this a "legitimate" change and worth building a
> new QGIS package?
> Best regards,
> Micha
> Micha Silver
> GIS Consulting
> 052-3665918http://www.surfaces.co.il
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130816/7f7dc5f5/attachment.html>
More information about the Live-demo mailing list
