[Live-demo] Emailing: GdalTools.zip
Jerome Villeneuve Larouche
jlarouche at mapgears.com
Fri Aug 16 08:16:57 PDT 2013
Hi Micha,
I looked a bit more into it and I think I've got a proper fix. I think
pretty much everything is back.
I attached the patch if you want to try it.
On 13-08-16 05:30 AM, Micha Silver wrote:
> After some testing this morning, I was not able to just add the
> versionNum() function to the GdalTools plugin. There are apparently
> other API changes in the 2.0 plugin that would need some additional
> backporting.
> So I tried instead Hamish's hack of just sticking in version "1.0.0"
> everywhere to fool the plugin. That seems to work fine. A quick test
> in a VM of last night's build showed that all the Raster menu items
> re-appear, and I ran two tools (that had disappeared) successfully.
> Having said that, I'm not really comfortable with this. It circumvents
> a test that *should* be in place. Even tho' there's zero chance of
> Ubuntu reverting back to gdal < 1.8. Any other opinions?
> Attached is a zip with the required patch files to the various
> GdalTools python scripts to get the menu working again.
> @ Jerome: Do you consider this a "legitimate" change and worth
> building a new QGIS package?
> Best regards,
> Micha
> Micha Silver
> GIS Consulting
> 052-3665918
> http://www.surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130816/629b765e/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130816/629b765e/attachment.bin>
More information about the Live-demo
