[Live-demo] [OSGeo] #1215: ossim ipython profile not working from chroot
OSGeo
trac_osgeo at osgeo.org
Wed Aug 21 13:33:09 PDT 2013
Reporter: hamish | Owner: live-demo@…
Type: defect | Status: new
Priority: major | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: ossim, ipython
the install_ipython.sh script pre-seeds a profile for ossim, but the funny
thing insists on writing to $HOME but doesn't like being run as sudo -u.
So the workaround for 6.5 was to run as root in the install script then
move the files over to $USER_HOME. that isn't working anymore.
mkdir -p "$USER_HOME"/.config/
ipython profile create osgeolive
mv ~/.ipython "$USER_HOME"/.config/ipython
but it is causing an error: (chroot's "root" home dir is /roots/)
/usr/lib/python2.7/dist-packages/IPython/utils/path.py:296: UserWarning:
IPython parent '/roots' is not a writable location, using a temp
directory.
" using a temp directory."%parent)
[ProfileCreate] Generating default config file:
u'/tmp/tmpTWZYb5/profile_osgeolive/ipython_config.py'
u'/tmp/tmpTWZYb5/profile_osgeolive/ipython_qtconsole_config.py'
u'/tmp/tmpTWZYb5/profile_osgeolive/ipython_notebook_config.py'
mv: cannot stat `/roots/.ipython': No such file or directory
sed: can't read /home/user/.config/ipython/profile_osgeolive/*.py: No such
file or directory
cp: cannot stat `/home/user/.config/ipython': No such file or directory
./install_ipython.sh: 72: ./install_ipython.sh: cannot create
/home/user/.config/ipython/profile_osgeolive/ipython_notebook_config.py:
Directory nonexistent
cp: cannot stat
`/home/user/.config/ipython/profile_osgeolive/ipython_notebook_config.py':
maybe "su -" as the $USER would work instead? someone with access to the
chroot environ might have to play to see what works..
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1215>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
