[Live-demo] [OSGeo] #1120: gpsbabel works only as root
OSGeo
trac_osgeo at osgeo.org
Fri Aug 23 17:42:06 PDT 2013
Reporter: micha | Owner: live-demo@…
Type: enhancement | Status: reopened
Priority: normal | Milestone: OSGeoLive7.5
Component: LiveDVD | Resolution:
Keywords: gps, gpsbabel, GPSTools |
Changes (by hamish):
* status: closed => reopened
* resolution: fixed =>
* milestone: OSGeoLive7.0 => OSGeoLive7.5
Comment:
does gpsd's xgps work? how about OpenCPN and GpsDrive? If GtkTerm is
installed on the disc (I forget if we did that or not) can you view the
NMEA stream? Is the GPS sending NMEA or proprietary binary format from
Prolific etc? Does it work when running on a real machine instead of a VM?
which VM software are you using?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1120#comment:6>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
