[Live-demo] [OSGeo] #1233: TinyOWS quickstart failure on 7.0rc2
OSGeo trac_osgeo at osgeo.org
Sun Aug 25 18:18:23 PDT 2013
 Reporter:  hamish    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  OSGeoLive7.0
Component:  LiveDVD   |    Keywords:  tinyows, pgrouting
 no luck with the 7.0rc2 quickstart for TinyOWS, there are a couple of
 problems:
  - connect to pgrouting PostGIS database in QGIS works, but the ways table
 doesn't look very healthy, all links back to one spot. or maybe that is
 the shortest path from a->b? as-is doesn't look healthy anyway. see
 screenshot.
  - the quickstart asks you to enable the WFS plugin in QGIS but it doesn't
 exist. if you go to the Fetch plugins there is a WFS 2.0 Client v.0.8.4 by
 J. Weichland, but you get the same NameSpace error as below.
  - no matter, Add WFS Layer is available from the menu anyway, add name
 and url as per quickstart, then ok, then Connect. but it leads to this
 error:
   ErrorConfigFile: No layer NameSpace prefix defined
 and that's as far as you get.
 /usr/lib/cgi-bin/tinyows does exist in the filesystem.
 Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1233>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
