[Live-demo] [OSGeo] #1234: pgRouting: PostGIS database ways table bad import os OSM data
OSGeo trac_osgeo at osgeo.org
Thu Aug 29 13:34:10 PDT 2013
 Reporter:  hamish    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  OSGeoLive7.0
Component:  LiveDVD   |    Keywords:  pgRouting
 moving this into its own ticket from #1233.
  * connect to pgrouting PostGIS database in QGIS works, but the ways table
 doesn't look very healthy, all links back to one spot. or maybe that is
 the shortest path from a->b? as-is doesn't look healthy anyway. see
 screenshot.
 I can confirm that the "all links back to one spot" problem in the
 pgrouting PostGIS db was not present in the 6.5 version of the live disc,
 so this is a new pgRouting problem too. (& perhaps a separate issue to the
 TinyOWS failure)
 I'm guessing that it can only mess up the routing results.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1234>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
