[Live-demo] [OSGeo] #1063: rasdaman dataset verification
OSGeo
trac_osgeo at osgeo.org
Sat Feb 2 18:07:27 PST 2013
Reporter: rasdaman | Owner: rasdaman
Type: defect | Status: assigned
Priority: normal | Milestone: OSGeoLive6.5
Component: LiveDVD | Keywords: 6.5, rasdaman
Comment(by hamish):
Replying to [comment:22 rasdaman]:
> I attached several images which show how 1D, 3D, 4D, 5D should
> look like (did not attached all demos for 1D, etc.). As before, I
> got the lastest build 9677 and ran the script install_rasdaman,
you re-ran in the install script? that's done as part of the build process
and shouldn't be necessary.
> and just issued start_rasdaman.sh script to start rasdaman server.
ah, ok I can get something now -- IF I run the tart_rasdaman.sh script
from a Terminal prompt, twice!
Perhaps some trouble with the tuning of the WAIT_FOR_CHILDREN part of the
startup script? Could an extra "sleep 3" somewhere help?
It returns to the command prompt after "starting all rasdaman servers..",
and rasmgr was running, but no "Started 10 servers on 1 host" (and no
rasserver processes either) until I ran it a second time. Note the exit
code after the first attempt was 39, another time 51, next time 37,... is
that trying to show the PID or the exit code of the rascontrol ($?)?
I still suspect there is an array size off by one error in the first 4D
demo, the diagonal skew looks like an error to me.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1063#comment:23>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
