[Live-demo] [OSGeo] #1063: rasdaman dataset verification
OSGeo trac_osgeo at osgeo.org
Sun Feb 3 14:27:15 PST 2013
 Reporter:  rasdaman  |       Owner:  rasdaman
     Type:  defect    |      Status:  assigned
 Priority:  normal    |   Milestone:  OSGeoLive6.5
Component:  LiveDVD   |    Keywords:  6.5, rasdaman
Comment(by kalxas):
 Replying to [comment:22 rasdaman]:
 > Replying to [comment:21 hamish]:
 > > Replying to [comment:17 rasdaman]:
 > > > It is working in build 9677, do you still have problem with that?
 > > Hi,
 > > out of curiosity, can you explain what is supposed to happen in the 1D
 demo? I get code snippets on mouse-over, and can select
 linear,area,scattered from the drop down list, but other than that no
 feedback, plot, or other output to look at. Is there a "submit" button I'm
 missing somewhere, or?
 > > thanks,
 > > Hamish
 > I attached several images which show how 1D, 3D, 4D, 5D should look like
 (did not attached all demos for 1D, etc.). As before, I got the lastest
 build 9677 and ran the script install_rasdaman, and just issued
 start_rasdaman.sh script to start rasdaman server.
 > Alireza
 Hi Alireza,
 I am not getting the same results.
 You have to test not by running the install script again but starting
 Rasdaman from Geospatial menu -> Databases -> Rasdaman
 Can you please test build 9758 and see what is the issue?
 Thanks,
 Angelos
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1063#comment:25>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
