[Live-demo] Suggest reworking PostGIS Quickstart to remove command-line interface
Alex Mandel
tech_dev at wildintellect.com
Sun Feb 3 14:49:42 PST 2013
To answer the question as posed in IRC. Yes I believe everything can be
done in the pgAdmin GUI. Especially now that the load extension function
is implemented when creating new databases. So it makes sense to me to
focus on the GUI and put a note that it can all be done without a GUI
for those interested.
Thanks,
Alex
On 02/03/2013 02:23 PM, Cameron Shorter wrote:
> I'm interested to hear feedback on my suggestion to restructure the
> PostGIS quickstart, primarily to drop the command line description in
> favour of a pgAdmin section.
> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/quickstart/postgis_quickstart.html
> On 04/02/13 09:20, OSGeo wrote:
>> #1085: PostGIS Quickstart review - remove command line description
>> Reporter: camerons | Owner: live-demo@…
>> Type: defect | Status: new
>> Priority: normal | Milestone: OSGeoLive6.5
>> Component: LiveDVD | Keywords: postgis, docs, 6.5
>> I've added the follow review comments into the PostGIS quickstart:
>> For this quickstart, which targets new users who might not be
>> familiar
>> with
>> databases or SQL, I suggest we drop section describing command line
>> control of Postgres. If we do keep command line information, I
>> suggest
>> it is moved to the end of the quickstart, possibly added into "Things
>> you
>> could try".
>> Instead, I think the Quickstart should cover:
>> * Keep Client/Server overview
>> * Create a database in pgAdmin
>> * Load a dataset, probably from a shapefile
>> * Do some SQL queries on the dataset
>> * Use QGis to view data from PostGIS (using the existing Natural
>> Earth
>> data). We should be able to keep most of the existing QGis sections
More information about the Live-demo
