[Live-demo] [OSGeo] #1063: rasdaman dataset verification
OSGeo trac_osgeo at osgeo.org
Tue Feb 5 02:55:08 PST 2013
 Reporter:  rasdaman  |       Owner:  rasdaman
     Type:  defect    |      Status:  assigned
 Priority:  normal    |   Milestone:  OSGeoLive6.5
Component:  LiveDVD   |    Keywords:  6.5, rasdaman
Comment(by rasdaman):
 Replying to [comment:25 kalxas]:
 > Replying to [comment:22 rasdaman]:
 > > Replying to [comment:21 hamish]:
 > > > Replying to [comment:17 rasdaman]:
 > > > > It is working in build 9677, do you still have problem with that?
 > > > Hi,
 > > > out of curiosity, can you explain what is supposed to happen in the
 1D demo? I get code snippets on mouse-over, and can select
 linear,area,scattered from the drop down list, but other than that no
 feedback, plot, or other output to look at. Is there a "submit" button I'm
 missing somewhere, or?
 > > > thanks,
 > > > Hamish
 > > I attached several images which show how 1D, 3D, 4D, 5D should look
 like (did not attached all demos for 1D, etc.). As before, I got the
 lastest build 9677 and ran the script install_rasdaman, and just issued
 start_rasdaman.sh script to start rasdaman server.
 > > Alireza
 > Hi Alireza,
 > I am not getting the same results.
 > You have to test not by running the install script again but starting
 Rasdaman from Geospatial menu -> Databases -> Rasdaman
 > Can you please test build 9758 and see what is the issue?
 > Thanks,
 > Angelos
 Hi Angelos,
 I tested ob build 9758 and it works the only caveat is that
 start_rasdaman.sh script (or alternatively Geospatial menu -> Databases ->
 Rasdaman -> Start Rasdaman Server) needs to be run 2 times. Please try
 again and verify. I get back to you when we solve this issue.
 Thanks,
 Cheers,
 Alireza
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1063#comment:26>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
