[Live-demo] [OSGeo] #1089: pgRouting needs legacy.sql
OSGeo
trac_osgeo at osgeo.org
Sat Feb 9 01:23:16 PST 2013
Reporter: hamish | Owner: live-demo@…
Type: defect | Status: closed
Priority: blocker | Milestone: OSGeoLive6.5
Component: LiveDVD | Resolution: fixed
Keywords: 6.5, pgrouting, postgis |
Comment(by hamish):
Replying to [comment:5 hamish]:
> yearning for some visual feedback I made a couple more changes
> in svn to try and get the workshop's GeoExt OpenLayers demo
> going. I recentered the map over the OSM extract in
> routing-*.html and adjusted the PG_DB and PG_USER variables
> in php/pgrouting.php, but no routing renders :-(
> Maybe something else needs tweaking too?
with some help from Brian I got it working:
* needed to symlink the workshop's web dir into /var/www, as the php
needed to be served to run
* After RTFM, it needed 'trust' level set for IPv4 'host' access in
pg_hba.conf. Wondering ways to avoid that... ~/.pgpass is already set up
and seems to be working elsewhere. ?
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1089#comment:6>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
