[Live-demo] [OSGeo] #1096: add ipython and ipython-notebook packages to the build
OSGeo
trac_osgeo at osgeo.org
Sat Feb 9 17:36:20 PST 2013
Reporter: darkblueb | Owner: live-demo@…
Type: enhancement | Status: new
Priority: normal | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords: ipython
Changes (by hamish):
* cc: epifanio (added)
Comment:
In a generic sense you should be able to configure any particular program
to use a particular port; it shouldn't be an issue to change that at will.
The problem with using common-looking port numbers is that everyone gets
the same idea from the same set of 10-15 and with 40 projects we get
conflicts (again). The solution is for everyone to avoid them- then if one
falls through the cracks unnoticed we are much less likely to have a
conflict.
The system-wide tomcat6 is a special case, it can use 8080. :)
Anything else has not been explicitly "allowed", it just hasn't gotten its
nasty-gram asking to use something else yet.
(mapnik's tilelite looks like it's running on port 8012, not 8000 by the
way)
for OSSIM the best alternative I could think up was the numberfied version
of the name ("M" doesn't translate very well though), 05514 -> 5514.
/etc/services shows nothing standard using that.
Is there a nice & concise highly-geo example for ipython? Or would it be
similar to the R and (now shelved) Octave framework quickstarts which
could perhaps use a GWR or similar geo-task added?
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1096#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
