[Live-demo] Status of full osgeolive 6.5?
Alex Mandel
tech_dev at wildintellect.com
Sat Feb 23 13:16:02 PST 2013
Something isn't right, after I worked around the hard coded paths that
didn't match my system it gave and error about size at the last step.
It sounds like it might be overridable with a flag to the geniso but
that might also result in file that's too big to burn.
"File ./casper/filesystem.squashfs is larger than 4GiB-1.
-allow-limited-size was not specified. There is no way do represent this
file size. Aborting."
The script cleaned itself up so I can't inspect the "bad" squashfs size.
Log is up
http://osprey.ucdavis.edu/downloads/osgeo/gisvm/6.5nightly/build_debug_full-12.log
Thanks,
Alex
On 02/23/2013 05:16 AM, Angelos Tzotsos wrote:
> Hi all,
> I just completed the fix for #1093 in r10035
> Hamish can you please review the script?
> Alex can you please try it? (heads up: you will have to change the
> mirror to point to your copy of mini iso)
> Hope this solves this and we can produce the final full iso too.
> Cheers,
> Angelos
> On 02/22/2013 10:39 PM, Hamish wrote:
>> Cameron wrote:
>>> https://trac.osgeo.org/osgeo/ticket/1093
>>> The current situation is
>>> that in the full iso, the index.html file in
>>> the Win/Mac? Downloads directory is not
>>> being removed as it should.
>> right, and replaced with symlinks back to the dirs in /cdrom.
>> besides the new index.html files the dirs need to be removed
>> as well.
>>> Options to try:
>>> 1. At the start of the bin/build_full_iso.sh, remove the
>>> doc/WindowsInstallers/index.rst
>>> and doc/MacInstallers/index.rst source files.
>> we tried that, it didn't work. those files are frozen up
>> inside the squashfs filesystem on the iso.
>>> 2. Retrospectively unpack the iso image, remove the index.html
>>> file, then repack the image.
>> right, & that's exactly what Angelos is planning on doing.
>> for 7.0 I've modified rc.local to make this choice at boot time,
>> based on the availablilty of the installers or not. Since the
>> mini iso is pretty much ready at this point it's too late for
>> this round so we'll do some open air brain surgery on the full
>> iso to fix it by hand this time. Not ideal, but we're pretty
>> familiar with the method by now.
>> regards,
>> Hamish
More information about the Live-demo
