[Live-demo] Build Process - Filesystems
Micha Silver Micha at arava.co.il
Thu Jan 3 04:31:21 PST 2013
Angelos Tzotsos wrote
> On 12/21/2012 12:17 PM, Patric Hafner | geOps wrote:
>> Dear Members of the OSGeo mailing list,
>> in last days, I run the build process as described here [1] several
>> times to test our install script. Unfortunately the building always
>> failed due to problem with unmouting of dev and proc-filesystem for
>> chroot.  After some small changes, I was able to fix this issue.
>> Do someone else also experienced those problems?
>> For me it is not obvious why it is necessary to bind the whole /dev into
>> the chroot - /dev/pts should do it. Secondly, it seems more safe to me,
>> to execute the mount of /proc outside the chroot.
>> After performing the following changes, building runs always fine in my
>> environment.
>> *build_chroot_debug.sh*
>> -- sudo mount --bind /dev/ edit/dev
>> ++ sudo mount -t proc -o bind /proc edit/proc
>> ++ sudo mount -o bind /dev/pts edit/dev/pts
>> -- sudo umount edit/dev
>> ++ sudo umount edit/dev/pts
>> ++ sudo umount edit/proc
>> *inchroot_debug.sh*
>> --mount -t proc none /proc
>> --mount -t sysfs none /sys
>> --mount -t devpts none /dev/pts
>> -- umount /proc || umount -lf /proc
>> -- umount /sys
>> -- umount /dev/pts
>> Any comments or ideas ?
>> [1]
>> http://wiki.osgeo.org/wiki/Live_GIS_Build#How_to_do_development_.2F_debugging_with_the_current_build_method
> Hi Patric,
> Thanks for your patch, I will test it too.
> The previous instructions came directly from the official Ubuntu wiki,
> so we did not touch them, and it worked ok (we simply had to reboot the
> build VM after a successful build process).
> Best,
> Angelos
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
> Live-demo mailing list
> Live-demo at .osgeo
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
I can verify that Patric's suggestion works. Successfully creates a build,
and also leaves the VM in a usable state.
Micha
View this message in context: http://osgeo-org.1560.n6.nabble.com/Build-Process-Filesystems-tp5024288p5025436.html
Sent from the OSGeo FOSS4G LiveDVD mailing list archive at Nabble.com.
More information about the Live-demo mailing list
