[Live-demo] [OSGeo] #1059: gpsdrive's Mapnik doesn't start since stuff changed
OSGeo
trac_osgeo at osgeo.org
Thu Jan 24 16:08:56 PST 2013
Reporter: hamish | Owner: live-demo@…
Type: defect | Status: new
Priority: normal | Milestone: OSGeoLive6.5
Component: LiveDVD | Keywords: gpsdrive, postgis2, 6.5
gpsdrive runs Mapnik to generate map tiles on-the-fly using the OSM data
loaded into PostGIS and shapefiles from Natural Earth for the coastline,
world city names, etc.
This failed in beta1.iso (cleanly, it just reverts to static satellite
image backdrop) since the shapefiles moved, specifically 10m_land.shp
isn't where it used to be and had a name change. I've fixed those in SVN
now, but the transition to PostGIS 2 now causes a crash:
terminate called after throwing an instance of
'mapnik::datasource_exception'
what(): :
ERROR: function asbinary(geometry) does not exist
LINE 1: SELECT AsBinary("way") AS geom,"aeroway","amenity","building...
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
Full sql was: 'SELECT AsBinary("way") AS
geom,"aeroway","amenity","building","highway",\
"landuse","leisure","man_made","military","natural","power","railway","tourism"
from \
(select * from planet_osm_polygon order by z_order,way_area desc)\
as leisure WHERE "way" && SetSRID('BOX3D(-134041.6 6972313.6,-130457.6
6975180.799999999)'::box3d, 900913)'
Aborted (core dumped)
hopefully a PostGIS expert can provide some tips, I'm not seeing any
asbinary() or AsBinary() in the gpsdrive source code.
http://gpsdrive.svn.sourceforge.net/viewvc/gpsdrive/trunk/src/database_postgis.c?revision=HEAD&view=markup
http://gpsdrive.svn.sourceforge.net/viewvc/gpsdrive/trunk/src/database_postgis.h?revision=HEAD&view=markup
in the mean time I've just set mapnik=0 in the ~/.gpsdrive rc file (see
gisvm/bin/install_gpsdrive.sh) to disable mapnik mode.
thanks for any pointers,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1059>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
