[Live-demo] Postgis 2.0 - legacy.sql
    Brian Hamlin
    maplabs at light42.com
    Fri Jan 25 10:50:34 PST 2013
Hi Sergio -
   we have already passed to Beta 1, so it is too late to make
changes like this.
In general, all other apps have ported to PostGIS 2.0, which was
released in April 2012.
PostGIS 2.0 is a major, and much improved update to PostGIS, and has
had extensive testing.
I see no benefit in using legacy.sql generally, and definitely not in
the standard data set for the disk.
I am certain that Kosmo can improve itself, and become current, with
some effort.
Please continue post your concerns in the tickets and on the mailing
list so we can discuss
best regards from Berkeley, California
Brian M Hamlin
OSGeo California Chapter
415-717-4462 cell
On Jan 24, 2013, at 11:55 PM, Sergio Baños Calvo wrote:
> Hi Angelos.
> From Kosmo part, it would be ok to change to postgis 2.0 if
> legacy.sql is loaded into at least the natural_earth2 database,
> that form part of the quickstart guide. But i think that if you
> load it into the postgis template database before creating the
> others spatial databases it could be better.
> I think that the ticket #1059 from the tracker [1] could be also
> solved loading the legacy.sql, as the offending sql function that
> it's not found is restored with the legacy.sql.
> Regards,
> [1] https://trac.osgeo.org/osgeo/ticket/1059
> El 25/01/2013 0:02, Angelos Tzotsos escribió:
>> Hi Sergio,
>> Yes we have pushed PostGIS 2.0 for this release of OSGeoLive.
>> Would this solution you propose be applied to a specific database?
>> I would like to hear more opinions on this.
>> I would vote +/- 0 on this since it is close to the RC and I don't
>> know if it will affect other applications on the disk.
>> Another idea would be to remove the PostGIS 2.0 quickstart part
>> for the 6.5 release and restore them for 7.0.
>> Thoughts?
>> Regards,
>> Angelos
>> On 01/24/2013 01:28 PM, Sergio Baños Calvo wrote:
>>> While following Kosmo Desktop Quickstart, I realized that PostGIS
>>> 2.X is used in the OSGeo LiveDVD 6.5.
>>> Kosmo Desktop 2.0.1 (and I suppose that some others applications
>>> present at the LiveDVD may have a similar problem) doesn't
>>> support PostGIS 2.X as it uses some functions that have been
>>> removed in the 2.X series (as extent(), geometryfromtext(), ...).
>>> In order to solve the PostGIS layers problems, could it be
>>> possible to load the legacy.sql file into the LiveDVD PostgreSQL
>>> database as pointed in [1]?
>>> Regards,
>>> [1] http://postgis.refractions.net/docs/PostGIS_FAQ.html#legacy_faq
>>> _______________________________________________ Live-demo mailing
>>> list Live-demo at lists.osgeo.org http://lists.osgeo.org/mailman/
>>> listinfo/live-demo http://live.osgeo.org http://wiki.osgeo.org/
>>> wiki/Live_GIS_Disc
>> -- Angelos Tzotsos Remote Sensing Laboratory National Technical
>> University of Athens http://users.ntua.gr/tzotsos
>> wiki/Live_GIS_Disc
> <!-- @page { size: 21cm 29.7cm; margin: 2cm } P { margin-bottom:
> 0.21cm } -->
> Sergio Baños Calvo
> Jefe de desarrollos
> Sistemas Abiertos de Información Geográfica, S.L. (SAIG S.L.)
> Tlfno. móvil: 685005960
> Tlfno. fijo: (+34) 954788876
> E-mail: sbc at saig.es
> Live-demo mailing list
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo
