[Live-demo] [OSGeo] #1059: gpsdrive's Mapnik doesn't start since stuff changed
OSGeo
trac_osgeo at osgeo.org
Fri Jan 25 23:21:53 PST 2013
Reporter: hamish | Owner: live-demo@…
Type: defect | Status: new
Priority: normal | Milestone: OSGeoLive6.5
Component: LiveDVD | Keywords: gpsdrive, postgis2, 6.5
Comment(by hamish):
fwiw "There is an alternative legacy_minimal.sql you can run instead
which will install barebones needed to recover tables and work with apps
like MapServer and GeoServer. If you have views that use things like
distance / length etc, you'll need the full blown legacy.sql"
http://www.postgis.org/docs/postgis_installation.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1059#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
