[Live-demo] [OSGeo] #1059: gpsdrive's Mapnik doesn't start since stuff changed
OSGeo trac_osgeo at osgeo.org
Mon Jan 28 01:07:32 PST 2013
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  OSGeoLive6.5
Component:  LiveDVD  |    Keywords:  gpsdrive, kosmo, postgis2, 6.5
Changes (by hamish):
  * keywords:  gpsdrive, postgis2, 6.5 => gpsdrive, kosmo, postgis2, 6.5
Comment:
 Replying to [comment:9 darkblueb]:
 > I do not understand how or why Kosmo can shift the base system
 > for all other apps -
 I don't think it's as bad as all that, legacy.sql seems to be a bolt-on
 plugin to help with apps in transition, not a replacement of anything.
 > I read above that GPSDrive is now (thankfully) resolved.
 "worked around" is probably the better way of putting it.
 the current solution for Kosmo is that the legacy.sql gets applied as part
 of the Kosmo startup script. There's no check for if that's been done
 before (a little help please?) so if Kosmo is run multiple times it will
 get applied multiple times. (maybe that's harmless?)
 there's a very good chance something else on the disc will also not be
 PostGIS 2.0 ready; we'll just have to wait and see.
 regards,
 Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1059#comment:10>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
