[Live-demo] Enable JSONP for GeoServer
Patric Hafner | geOps patric.hafner at geops.de
Tue Jul 2 07:19:36 PDT 2013
Hello everybody,
we are currently fixing the installer for Cartaro
(http://trac.osgeo.org/osgeo/ticket/1136).
In order to run Cartaro with GeoServer 2.3, it is necessary to set the
java system variable ENABLE_JSONP=true to enable the JSONP
(text/javascript) output format.
This can be done in /usr/local/lib/geoserver-2.3.2/bin/startup.sh Line 71
-  export JAVA_OPTS="-XX:MaxPermSize=128m"
+  export JAVA_OPTS="-XX:MaxPermSize=128m -DENABLE_JSONP=true"
(More Information:
http://docs.geoserver.org/stable/en/user/services/wms/global.html#wms-global-variables)
Does someone see any problems with activating it? Especially the other
projects using GeoServer?
As the startup.sh script is part of the GeoServer archive, I want to fix
the script in the same way (using sed) as it already happens in
install_geoserver.sh (around Line 80)
If this is o.k. for everybody, it would commit this change.
Thoughts?
With best regards,
Patric
We are hiring: http://www.geops.de/jobs
web www.geops.de
rss www.geops.de/blog/feed
follow www.twitter.com/geops_tweet
More information about the Live-demo mailing list
