[Live-demo] ncWMS installer added
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Jul 3 06:05:15 PDT 2013
Hi Guy,
Thanks for your e-mail. I am keeping the mailing list in CC so that
others can comment/provide suggestions too.
Some comments inline:
On 07/03/2013 01:35 PM, Guy Griffiths wrote:
> Angelos,
> I am having a couple of problems with the installer and Cameron
> suggested I talk to you about them. If you think they are better
> suited to the mailing list please feel free to move this conversation
> there.
> I have downloaded the nightly build ISO (for 02/07/13) and run it in a
> virtual machine. There are links for "Start ncWMS" and "Stop ncWMS"
> as expected. However, there are 2 of each, and they are found in the
> "Other" menu. Could you explain how the links in Desktop get moved to
> the correct menu? Or simply how to get them in the right menu and
> only have one of each?
Thanks for your testing of the nightly builds.
This issue is something that I have noticed too, and have tried to fix a
couple of times.
Menus are configured in the following files:
http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/install_icons_and_menus.sh
http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/desktop-conf/xfce/xfce-osgeo.menu
I have added ncWMS in there as you can see, but for some unknown reason
it gets moved to "Others" folder... still searching this issue.
I opened a ticket for this:
http://trac.osgeo.org/osgeo/ticket/1152
> The second problem is that the "Start ncWMS" link doesn't work after
> installing the live DVD to the hard drive. I know this was discussed
> on the mailing list (issue #1141 - Projects using default tomcat...),
> but I have copied the script used by 52nWPS and others:
> #!/bin/bash
> STAT=\`sudo service tomcat6 status | grep pid\`
> if [ "\$STAT" != "" ]; then
> sudo service tomcat6 start
> (sleep 2; echo "25"; sleep 2; echo "50"; sleep 2; echo "75"; sleep
> 2; echo "100") | zenity --progress --auto-close --text "ncWMS starting"
> fi
> firefox $WMS_URL/godiva2.html $WMS_QUICKSTART_URL $WMS_OVERVIEW_URL
> However I have checked 52nWPS and others and they have the same
> problem - tomcat is not started. To clarify, this works fine on the
> live DVD, and only fails after installation to the hard drive.
This is a known issue, but I forgot to open a ticket for this.
What is the user name you used during installation?
As a workaround, you can add to the /etc/sudoers.d the following:
*<username> ALL=(root) NOPASSWD: /usr/sbin/service tomcat6
start,/usr/sbin/service tomcat6 stop,/usr/sbin/service tomcat6 status*
We need to find a way to handle this for installed systems.
http://trac.osgeo.org/osgeo/ticket/1153
> Any help you can give me would be much appreciated.
> Regards,
> Guy Griffiths
Regards,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130703/6d11938d/attachment.html>
More information about the Live-demo
