[Live-demo] [OSGeo] #1152: ncWMS launchers not installed in Geospatial menu
OSGeo trac_osgeo at osgeo.org
Thu Jul 4 04:08:38 PDT 2013
 Reporter:  kalxas   |       Owner:  hamish
     Type:  defect   |      Status:  assigned
 Priority:  normal   |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:  ncWMS, menus
Comment(by hamish):
 hopefully fixed in r10289.
 I also noted some issues in the script with '###', most serious is to
 decide if automatic pw entry for sudo is desired when installed as a VM
 (on the VM sudo asks you for a pw, on the iso it doesn't AFAIU). the
 trouble (if you call it that) is that often the VM creator will make
 another user account &/or change the paswd, then the automatic pw passing
 to sudo becomes out of date and fails. note from the icon if it asks you
 for the sudo pw there is no tty to enter it, so it fails anyway.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1152#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
