[Live-demo] [OSGeo] #1154: PostGIS failed to install from UbuntuGIS repository
OSGeo trac_osgeo at osgeo.org
Fri Jul 5 18:03:44 PDT 2013
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:
 Some packages could not be installed. This may mean that you have
 requested an impossible situation or if you are using the unstable
 distribution that some required packages have not yet been created
 or been moved out of Incoming.
 The following information may help to resolve the situation:
 The following packages have unmet dependencies:
  postgis : Depends: libgdal1h (>= 1.9.0) but it is not going to be
 installed
 E: Unable to correct problems, you have held broken packages.
 ERROR: Package install failed! Aborting.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1154>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
