[Live-demo] [OSGeo] #1154: PostGIS failed to install from UbuntuGIS repository
OSGeo trac_osgeo at osgeo.org
Sun Jul 7 14:16:41 PDT 2013
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:
Comment(by hamish):
 Replying to [comment:5 kalxas]:
 > Is there a way to revert postgis to previous deb file?
  apt-get install package=exact_version-numbers
 Setting up postgis (2.0.1-2~precise3) ...
 Setting up postgresql-9.1-postgis (2.0.1-2~precise3) ...
 e.g.
  apt-get install postgis=2.0.1-2~precise3
 postgresql-9.1-postgis=2.0.1-2~precise3
 (check old build logs to get the version numbers)
 and hopefully the ppa retains the old versions in the pool.
 you may need to check available versions with "apt-cache policy postgis"
 and to avoid it being later upgraded put a hold on the package(s) with:
 `echo "package_name hold" | dpkg --set-selections`.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1154#comment:7>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
