[Live-demo] [OSGeo] #1154: PostGIS failed to install from UbuntuGIS repository
OSGeo trac_osgeo at osgeo.org
Wed Jul 10 06:35:25 PDT 2013
 Reporter:  kalxas   |        Owner:  live-demo@…
     Type:  defect   |       Status:  reopened
 Priority:  blocker  |    Milestone:  OSGeoLive7.0
Component:  LiveDVD  |   Resolution:
 Keywords:           |
Comment(by jlarouche):
 New package is up on Precise with the contrib folder.
 You can remove the postgresql-9.1-postgis-2.0-scripts from apt-get and
 change postgresql-9.1-postgis to posgresql-9.1-postgis-2.0. Keep postgis
 and proj. This will install PostgreSQL, the Postgis lib and scripts.
 I tried running the same command you're using in the script in a clean VM
 and it all seems to be working fine and I've been running a PostGIS DB on
 Raring using the new PostGIS package and it all seem fine.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1154#comment:18>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
