[Live-demo] isntalled pkgs on build 10446
maplabs at light42.com maplabs at light42.com
Sun Jul 21 13:21:47 PDT 2013
generated using a python hack of the build log,
this may be a list of the packages installed by the build process:
a2ps ant apache2 apache2.2-bin apache2.2-common
apache2-mpm-prefork apache2-utils apturl apturl-common arandr
autoconf automake autotools-dev avce00 bicyclerepair blt
ca-certificates-java cgi-mapserver cmake cmake-data csh cvs
cvsutils cython dbview diff docbook-xsl docutils-common e00compr
emacsen-common eric fakeroot filelight freeglut3 fslint fuseiso
fuse-utils g++ g++-4.6 gawk gdal-bin gdebi gdebi-core gettext
gfortran gfortran-4.6 giblib1 gmt gmt-coast-low gmt-doc
gmt-examples gmt-tutorial gmt-tutorial-pdf gnuplot gnuplot-nox
gnuplot-x11 gpsbabel gpsd gpsd-clients gpsprune graphicsmagick
graphicsmagick-imagemagick-compat grass grass-core grass-doc
grass-gui gsfonts-x11 gv gxmessage imagemagick-common imposm
iotop java-common java-wrappers josm josm-plugins kate-data
katepart kdelibs5-data kdelibs5-plugins kdelibs-bin kde-runtime
kde-runtime-data kdoctools language-pack-ar
language-pack-ar-base language-pack-de language-pack-de-base
language-pack-el language-pack-el-base language-pack-fi
language-pack-fi-base language-pack-he language-pack-he-base
language-pack-hi language-pack-hi-base language-pack-id
language-pack-id-base language-pack-it language-pack-it-base
language-pack-ja language-pack-ja-base language-pack-ko
language-pack-ko-base language-pack-pl language-pack-pl-base
language-pack-ro language-pack-ro-base language-pack-ru
language-pack-ru-base language-pack-th language-pack-th-base
language-pack-vi language-pack-vi-base language-pack-zh-hant
language-pack-zh-hant-base lesstif2 lftp libamd2.2.0
libaopalliance-java libapache2-mod-fcgid libapache2-mod-php5
libapache2-mod-wsgi libapache-pom-java libaprutil1-dbd-sqlite3
libaprutil1-ldap libarmadillo2 libasm3-java
libatinject-jsr330-api-java libatk-wrapper-java
libatk-wrapper-java-jni libattica0.3 libaudio2
libavalon-framework-java libavcodec53 libavdevice53
libavformat53 libavutil51 libbatik-java libbcel-java libblas3gf
libblas-dev libboost1.46-dev libboost-date-time1.46.1
libboost-date-time1.46-dev libboost-filesystem1.46.1
libboost-filesystem1.49.0 libboost-program-options1.46.1
libboost-program-options1.46-dev libboost-python1.46.1
libboost-regex1.46.1 libboost-regex1.49.0
libboost-serialization1.46.1 libboost-serialization1.46-dev
libboost-system1.46.1 libboost-system1.49.0
libboost-thread1.46.1 libboost-thread1.46-dev libbsf-java
libc3p0-java libc-client2007e libclucene0ldbl libcoin60
libcommons-codec-java libcommons-collections3-java
libcommons-compress-java libcommons-dbcp-java libcommons-io-java
libcommons-logging-java libcommons-parent-java
libcommons-pool-java libcurl3 libdap11 libdapclient3
libdbd-mysql-perl libdbi-perl libdbusmenu-qt2 libdc1394-22
libdirectfb-1.2-9 libdlrestrictions1 libdvdnav4 libdvdread4
libecj-java libepsilon0 libfaad2 libfcgi0ldbl libfftw3-3
libfltk1.3 libfltk-gl1.3 libfreexl1 libgdal1-1.7.0 libgdal1h
libgeos-3.2.2 libgeos-3.3.8 libgeos-c1 libgeos++-dev libgeotiff2
libgettext-commons-java libgettextpo0 libgfortran3 libgif4
libglib2.0-dev libgmt4 libgpgme11 libgps20 libgraphicsmagick3
libgsl0ldbl libgsm1 libgssglue1 libhdf4-0 libhdf4-0-alt
libhdf5-serial-1.8.4 libhpdf-2.2.1 libhunspell-1.2-0 libidl0
libidl-common libimlib2 libiso9660-8 libjavascriptcoregtk-1.0-0
libjaxp1.3-java libjgrapht0.8-java libjpeg62 libjpf-java
libjs-leaflet libjs-sphinxdoc libjs-underscore
libkatepartinterfaces4 libkcmutils4 libkde3support4
libkdeclarative5 libkdecore5 libkdesu5 libkdeui5 libkdewebkit5
libkdnssd4 libkemoticons4 libkfile4 libkhtml5 libkidletime4
libkio5 libkjsapi4 libkjsembed4 libkmediaplayer4 libkml0
libknewstuff3-4 libknotifyconfig4 libkntlm4 libkparts4
libkprintutils4 libkpty4 libkrosscore4 libktexteditor4
liblapack3gf liblapack-dev liblas1 liblog4j1.2-java liblqr-1-0
liblwgeom-2.0.3 libmagickcore4 libmagickwand4 libmapnik
libmapnik2-2.0 libmapserver libmarblewidget13 libmcrypt4
libmetadata-extractor-java libmodplug1 libmotif4 libmpcdec6
libmuparser0debian1 libmx4j-java libmysqlclient18 libmysql-java
libnepomuk4 libnepomukdatamanagement4 libnepomukquery4a
libnepomuksync4 libnepomukutils4 libnetcdf6 libnet-daemon-perl
libnetpbm10 libnova-0.12-2 libntrack0 libntrack-qt4-1
liboauth-signpost-java libodbc1 libogdi3.2 libokularcore1abi1
libopencv-core2.3 libopencv-ml2.3 libopenscenegraph80
libopenthreads14 libosgearth1 libosmpbf-java libotb libotb3.18
libparallel-forkmanager-perl libphonon4 libplasma3
libplexus-classworlds-java libplrpc-perl libpolkit-qt-1-1
libpoppler-qt4-3 libpostgis-java libpostgresql-jdbc-java
libpostproc52 libpq5 libproj0 libprotobuf7 libprotobuf-c0
libprotobuf-java libpth20 libqca2 libqgis1.8.0 libqimageblitz4
libqscintilla2-8 libqt4-dbus libqt4-declarative libqt4-designer
libqt4-gui libqt4-help libqt4-network libqt4-opengl
libqt4-qt3support libqt4-script libqt4-scripttools libqt4-sql
libqt4-sql-psql libqt4-svg libqt4-test libqt4-xml
libqt4-xmlpatterns libqtassistantclient4 libqtcore4 libqtgui4
libqtwebkit4 libqwt5-qt4 libqwt6 librasterlite1 libreadosm1
libsaga libschroedinger-1.0-0 libsdl1.2debian libservlet2.5-java
libsigsegv2 libsolid4 libsoprano4 libspatialindex1
libspatialite3 libspatialite5 libspring-aop-java
libspring-beans-java libspring-context-java libspring-core-java
libspring-expression-java libspring-jdbc-java
libspring-transaction-java libsprng2 libsqlite0 libssh-4
libssl-dev libstdc++6-4.6-dev libstreamanalyzer0 libstreams0
libsvg libsvg-cairo libsvgsalamander-java libsvn-perl
libswscale2 libterm-readkey-perl libthreadweaver4 libtiff-tools
libtinyxml2.6.2 libtirpc1 libtokyocabinet8 libtomcat6-java
libts-0.0-0 libumfpack5.4.0 libunistring0 liburiparser1 libva1
libvcdinfo0 libvirtodbc0 libvpx1 libwebkitgtk-1.0-0
libwebkitgtk-1.0-common libwxbase2.8-0 libwxbase2.8-dev
libwxbase2.9-0-unofficial libwxgtk2.8-0 libwxgtk2.8-dev
libwxgtk2.9-0-unofficial libxalan2-java libxcb-xv0
libxerces2-java libxerces-c28 libxerces-c3.1 libxine1
libxine1-bin libxine1-console libxine1-ffmpeg
libxine1-misc-plugins libxine1-plugins libxine1-x libxml2
libxml2-utils libxml-commons-external-java
libxml-commons-resolver1.1-java libxmlrpc-core-c3 libzbar0
locate lynx lynx-cur mapserver-bin marble marble-data
marble-plugins mc mc-data medit menu mercurial mercurial-common
merkaartor mlock monteverdi mutt mysql-client-5.5
mysql-client-core-5.5 mysql-common mysql-server mysql-server-5.5
mysql-server-core-5.5 nedit netcdf-bin netpbm nodejs
ntrack-module-libnl-0 odbcinst odbcinst1debian2 okular
openjdk-7-jdk openjdk-7-jre openjdk-7-jre-headless
openjdk-7-jre-lib openscenegraph openstreetmap-map-icons-classic
openstreetmap-map-icons-scalable openstreetmap-map-icons-square
optipng osgearth osgearth-data osm2pgsql osmosis otb-bin
otb-bin-common otb-bin-qt oxygen-icon-theme p7zip pgadmin3
pgadmin3-data phonon phonon-backend-gstreamer php5 php5-cgi
php5-cli php5-common php5-curl php5-gd php5-gdal php5-imagick
php5-imap php5-intl php5-mapscript php5-mcrypt php5-mysql
php5-pgsql php5-sqlite php-apc plasma-scriptengine-javascript
postgis postgresql postgresql-9.1 postgresql-9.1-postgis-2.0
postgresql-9.1-postgis-2.0-scripts postgresql-client-9.1
postgresql-client-common postgresql-common proj-bin proj-data
psutils pycsw-cgi python2.7-dev python-agon-ratings python-antlr
python-bs4 python-central python-dateutil python-dialogos
python-django python-django-activity-stream
python-django-announcements python-django-appconf
python-django-extensions python-django-forms-bootstrap
python-django-friendly-tag-loader python-django-geoexplorer
python-django-jsonfield python-django-nose
python-django-notification python-django-pagination
python-django-south python-django-taggit
python-django-taggit-templatetags
python-django-templatetag-sugar python-django-user-accounts
python-docutils python-gdal python-geonode python-geonode-avatar
python-gisdata python-gps python-gsconfig python-httplib2
python-imposm python-imposm-parser python-jinja2 python-lxml
python-mapnik2 python-mapscript python-markupsafe
python-matplotlib python-matplotlib-data python-mock
python-multipartposthandler python-nose python-numpy
python-opengl python-owslib python-paver
python-pinax-theme-bootstrap
python-pinax-theme-bootstrap-account python-pip python-ply
python-psycopg2 python-pycsw python-pygments python-pyke
python-pyparsing python-pyproj python-qgis python-qgis-common
python-qscintilla2 python-qt4 python-qt4-sql python-qwt5-qt4
python-roman python-rpy python-rpy2 python-scipy
python-setuptools python-shapely python-sip python-six
python-sphinx python-sqlalchemy python-support python-tk
python-tz python-user-messages python-werkzeug python-wxgtk2.8
python-wxversion python-xlrd python-xlwt qgis qgis-common
qgis-mapserver qgis-plugin-grass qgis-plugin-grass-common
qgis-providers qgis-providers-common qiv rasterlite-bin
r-base-core r-cran-boot r-cran-class r-cran-cluster
r-cran-codetools r-cran-foreign r-cran-kernsmooth r-cran-lattice
r-cran-mass r-cran-matrix r-cran-mgcv r-cran-nlme r-cran-nnet
r-cran-rpart r-cran-spatial r-cran-survival rlwrap rpcbind
r-recommended rxvt saga screen scrot sgt-puzzles
shared-desktop-ontologies sl soprano-daemon spatialite-bin
sphinx-common sqlite sqlite3 sqlitebrowser subversion-tools
tcl8.5-dev tilemill tinyows tk8.5 tk8.5-dev tomcat6
tomcat6-admin tomcat6-common transifex-client tsconf ttf-dejavu
ttf-dejavu-extra ttf-unifont tzdata-java units unixodbc viking
vim vim-runtime virtuoso-opensource-6.1-common vnc4server
wx2.8-headers xaw3dg xbase-clients xfce4-battery-plugin
xfce4-wavelan-plugin xfonts-100dpi xfonts-75dpi xfonts-jmk xml2
xmlstarlet xtide-coastline xulrunner-1.9.2 zlib1g-dev zygrib
Brian M Hamlin
OSGeo California Chapter
More information about the Live-demo mailing list
