[Live-demo] [OSGeo] #1168: Configure GeoNode to use postgis and fix permission problems
OSGeo
trac_osgeo at osgeo.org
Mon Jul 22 17:11:50 PDT 2013
Reporter: ingenieroariel | Owner: live-demo@…
Type: task | Status: new
Priority: major | Milestone: OSGeoLive7.0
Component: LiveDVD | Keywords:
Jeff Johnson provided a guide in https://gist.github.com/jj0hns0n/6058788
# set to use sqlite by default, cant create superuser cuz read-only db
# use postgres
sudo su - postgres
createuser geonode
psql -c "alter user geonode with encrypted password 'geonode';"
createdb -O geonode geonode
sudo vi /etc/postgresql/9.1/main/pg_hba.conf
# change local access to password
sudo /etc/init.d/postgresql restart
# setup local_settings.py
cd /usr/lib/python2.7/dist-packages/geonode/
sudo wget
https://raw.github.com/GeoNode/geonode/master/geonode/local_settings.py.sample
sudo mv local_settings.py.sample local_settings.py
sudo /etc/init.d/apache2 restart
# syncdb
django-admin syncdb --settings=geonode.settings --all
# create a superuser (one from fixtures doesnt seem to work)
django-admin createsuperuser --settings=geonode.settings
# change to port 8082 in settings.py
django-admin updatelayers --settings=geonode.settings
# make the uploaded dir
sudo mkdir /usr/lib/python2.7/dist-packages/geonode/uploaded
sudo chown user:user /usr/lib/python2.7/dist-packages/geonode/uploaded
# run updatelayers
# this will have created the dirs under uploaded to be owned by user
# chown them to apache
sudo chown -R www-data:www-data /usr/lib/python2.7/dist-
# collectstatic
django-admin collectstatic --settings=geonode.settings
# change apache entry to static_root
# line 21 change to static root
sudo vi /etc/apache2/sites-available/geonode
# bounce apache for good measure
#cp some shapefiles to your home dir to test upload
cp /usr/share/pyshared/django/contrib/gis/tests/data/interstates/* .
# test upload in browser
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1168>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
