[Live-demo] GeoNode application for LiveDVD
Stephan Meißl
stephan at meissl.name
Fri Jun 14 00:25:27 PDT 2013
On 06/14/2013 01:21 AM, Ariel Nunez wrote:
> Cameron,
>>> The key stumbling block we will need to resolve is whether there is sufficient space.
>>> In particular, we need to ensure that upstream applications, such as GeoServer are not installed twice.
> - The actual .deb file for GeoNode is less than 3Mb.
> - The python dependencies are about 50mb (including Django, pycsw,
> Shapely), many of this are already in the live dvd, we will do our best
> to use them if they are installed systemwide.
Just a quick heads-up that I'm going to change the EOxServer install
script which is currently installing Django to using virtualenv unless
we find a better solution.
cu
Stephan
> - The rest is Java VM, GeoServer, Postgis, Apache, mod_wsgi that we will
> for sure use if they are available.
> Where can I get the latest alpha/beta install CD for version 7? I can
> put that in a vagrant machine and see exactly how much GeoNode is
> adding, chances are the figure can be lower than 50mb.
>>> I'd also like to ensure that we are not introducing more example
> datasets, unless the example datasets offer something beyond what is
> already available (such as providing a different format). This to both
> save space, and also provide continuity between quickstarts and examples
> from different applications.
> No problem about the new datasets, we can use the ones there are already
> in the liveDVD for GeoServer.
>>> So my vote is +1 for including geonode on OSGeo-Live, if we can
> resolve the above.
> Thanks!
> Ariel.
More information about the Live-demo
