[Live-demo] [OSGeo] #1129: GeoNetwork includes internal GeoServer
OSGeo trac_osgeo at osgeo.org
Sun Jun 30 23:12:11 PDT 2013
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:
Comment(by fxp):
 Error on startup:
 2013-07-01 06:10:13.357:WARN::FAILED
 o.e.j.w.WebAppContext{/geonetwork,file:/usr/lib/geonetwork/web/geonetwork/},/usr/lib/geonetwork/web/geonetwork:
 java.lang.ExceptionInInitializerError
 2013-07-01 06:10:13.357:WARN::Unable to reach node goal: started
         at org.fao.geonet.resources.Resources.<clinit>(Resources.java:43)
         at org.fao.geonet.Geonetwork.start(Geonetwork.java:275)
         at
 jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:600)
         at jeeves.server.JeevesEngine.init(JeevesEngine.java:206)
         at
 jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:91)
         at javax.servlet.GenericServlet.init(GenericServlet.java:241)
         at
 org.eclipse.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:432)
         at
 org.eclipse.jetty.servlet.ServletHolder.doStart(ServletHolder.java:260)
         at
 org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:55)
         at
 org.eclipse.jetty.servlet.ServletHandler.initialize(ServletHandler.java:763)
         at
 org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:245)
         at
 org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1158)
         at
 org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:587)
         at
 org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:436)
         at
         at
 org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:36)
         at
 org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:180)
         at
 org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:479)
         at
 org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:136)
         at
 org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:137)
         at
 org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:50)
         at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:494)
         at
 org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:406)
         at org.eclipse.jetty.util.Scanner.scan(Scanner.java:355)
         at org.eclipse.jetty.util.Scanner.start(Scanner.java:290)
         at
 org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:114)
         at
         at
 org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:540)
         at
 org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:219)
         at
         at
 org.eclipse.jetty.util.component.AggregateLifeCycle.doStart(AggregateLifeCycle.java:42)
         at
 org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:52)
         at
 org.eclipse.jetty.server.handler.HandlerWrapper.doStart(HandlerWrapper.java:96)
         at org.eclipse.jetty.server.Server.doStart(Server.java:258)
         at
         at
 org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1233)
         at java.security.AccessController.doPrivileged(Native Method)
         at
 org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1156)
         at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
         at
 sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
         at
 sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
         at java.lang.reflect.Method.invoke(Method.java:601)
         at org.eclipse.jetty.start.Main.invokeMain(Main.java:477)
         at org.eclipse.jetty.start.Main.start(Main.java:623)
         at org.eclipse.jetty.start.Main.parseCommandLine(Main.java:273)
         at org.eclipse.jetty.start.Main.main(Main.java:81)
 Caused by:
 java.lang.SecurityException: sealing violation: package
 com.sun.media.imageioimpl.stream is sealed
         at
 java.net.URLClassLoader.getAndVerifyPackage(URLClassLoader.java:388)
         at java.net.URLClassLoader.defineClass(URLClassLoader.java:417)
         at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
         at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
         at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
         at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
         at
 org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:411)
         at
 org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:373)
         at java.lang.Class.forName0(Native Method)
         at java.lang.Class.forName(Class.java:266)
         at
 java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:363)
         at java.util.ServiceLoader$1.next(ServiceLoader.java:445)
         at
 javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210)
         at javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:138)
         at
 javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159)
         at javax.imageio.ImageIO.<clinit>(ImageIO.java:65)
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
         at
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1129#comment:5>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
