[Live-demo] [deegree-users] deegree webservices 3.2.0 released
Cameron Shorter
cameron.shorter at gmail.com
Sat Mar 30 13:09:53 PDT 2013
Our primary drivers for OSGeo-Live is as an introduction to Geospatial
Open Source applications, although that is now expanding as people use
OSGeoLive for workshops.
Also, OSGeo-Live is space constrained, so if we are to add a new
dataset, it should be relatively small, and should be useful for
multiple projects, (as well as being available under an open license
such as Creative Commons).
For the quickstart, I'd suggest that you stick to the core simple use
case which Deegree is being used for. Unless your core use case is
serving complex schema data, then it probably isn't a candidate for the
quickstart? Alternatively, if you are using OSGeo-Live within workshops
for Deegree, then we may consider introducing a complex schema dataset.
I'm aware that GeoServer also supports complex schemas, so I'd want to
ensure that the GeoServer community can make use of the dataset too.
So, key questions:
1. Is the complex schema use case the core 10 min use case you'd want to
present for Deegree's quickstart?
2. Are you using OSGeo-Live for workshops, and want a complex schema
dataset to demo functionality?
3. Can you source a small, open, complex schema dataset, preferably
covering an Area of Interest already included in existing OSGeo-Live
example datasets?
On 31/03/13 01:43, Markus Schneider wrote:
> Hi Cameron,
> thanks for your feedback/suggestions.
> I guess we (the deegree project) still got somework to do in order to
> get closer to using the data already available in OSGeoLive. Probably it
> seems that the deegree project always expects to get special treatment.
> Sorry for that :-(
> I guess we definitely should have a closer look at the Natural Earth
> example dataset. Maybe we can provide a deegree workspace based on that
> dataset. And write a quickstart tutorial based on that workspace.
> On the other hand, the real strength of deegree webservices is not
> common webmapping. It's probably quite a bit lot slower than MapServer
> and GeoServer here. I guess our most obvious raison d'être is our focus
> on in-depth support for rich data models, such as INSPIRE Data Themes,
> GeoSciML and all these German schemas like XPlanung and AAA. Do you
> think we can include some GML-encoded INSPIRE datasets on OSGeoLive?
> Some datasets can be found in our "INSPIRE workspace" [1].
> Best regards,
> Markus
> [1]
> http://download.deegree.org/documentation/3.2.0/html/lightly.html#example-workspace-1-inspire-network-services
> Am 30.03.2013 10:39, schrieb Cameron Shorter:
>> I like the style of this documentation that you reference. It is well
>> written, with diagrams which make it easy for someone with minimal
>> experience to follow.
>> A couple of suggestions that I have after a quick look at the docs are:
>> 1. With the quickstart, we are looking to show one core example of the
>> application in ~ 10 minutes. My first impression is that this chapter
>> you reference is probably a bit too long. I'd suggest 2 rather than 4
>> examples. Reason for keeping the docs concise is that we need to be
>> aware that the docs are translated into over 10 languages, and the cost
>> of maintenance becomes quite high.
>> 2. Could you please make use of example data that is already installed
>> on OSGeoLive rather than downloading from an external source. (You might
>> want to use the Natural Earth example datasets in your standard
>> documentation too).
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130331/6d9a8976/attachment.html>
More information about the Live-demo
