[Live-demo] Opticks
Alex Mandel
tech_dev at wildintellect.com
Fri May 17 12:43:36 PDT 2013
On 05/17/2013 12:40 PM, Pieter du Plooy wrote:
> Guys
> Second question for the evening.
> Is 6.5 still 32 bit only? (I am downloading 6.5 now, so if you read my
> previous thread I have not even installed 6.5. After installing 6.5 I will
> do the postgres bit if it is doa-able) If so does anyone know where I can
> get a 32 bit version of Opticks, or is it easy to compile for 32 bit?
> (They only have 64 bit debs and rpm's)
> Pieter
Yes, 6.5 is only 32 bit. You might be getting to the place where
installing a mainstream Ubuntu based distro (64 bit) and then
selectively installing the apps you want makes more sense.
All of our scripts are available to assist you in doing the
installations on a 64 bit system.
Our project is not intended to be a distro replacement. We don't support
updates, upgrades outside of releasing new canned versions every 6 months.
Thanks,
Alex
More information about the Live-demo
