[Live-demo] QGIS error
Carsten Hogertz carsten.hogertz at gmail.com
Mon Oct 14 22:17:42 PDT 2013
Solution was: deleted the ~/.qgis2 and started qgis from terminal by
running simply qgis. Started without problem. The menu starter uses root
to start up the program. So edited it and now it starts with the normal
user.
thanks everybody
Am 14.10.2013 22:36, schrieb Angelos Tzotsos:
> FYI, you willl need to chown the ~/.qgis2 folder to your custom user
> to make qgis work as expected.
> Cheers,
> Angelos
> On 10/13/2013 12:38 PM, Carsten Hogertz wrote:
>> Hi everybody,
>> somehow I updated QGIS on my OSGeo 7 to QGIS 2.0.1-Dufour. When starting
>> QGIS I now get an error telling:
>>   Konnte Erweiterung processing nicht laden wegen eines Fehler beim Aufruf
>> seiner classFactory()-Methode
>> Traceback (most recent call last):
>>    File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 204, in
>> startPlugin
>>      plugins[packageName] = package.classFactory(iface)
>>    File "/usr/share/qgis/python/plugins/processing/__init__.py", line 33, in
>> classFactory
>>      return ProcessingPlugin(iface)
>>    File "/usr/share/qgis/python/plugins/processing/ProcessingPlugin.py",
>> line 53, in __init__
>>      Processing.initialize()
>>    File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line
>> 127, in initialize
>>      Processing.addProvider(RAlgorithmProvider())
>> 75, in addProvider
>>      provider.initializeSettings()
>>    File "/usr/share/qgis/python/plugins/processing/r/RAlgorithmProvider.py",
>> line 51, in initializeSettings
>>      ProcessingConfig.addSetting(Setting(self.getDescription(),
>> RUtils.RSCRIPTS_FOLDER, "R Scripts folder", RUtils.RScriptsFolder()))
>>    File "/usr/share/qgis/python/plugins/processing/r/RUtils.py", line 55, in
>> RScriptsFolder
>>      mkdir(folder)
>>    File "/usr/share/qgis/python/plugins/processing/core/ProcessingUtils.py",
>> line 95, in mkdir
>>      mkdir(head)
>> line 97, in mkdir
>>      os.mkdir(newdir)
>> OSError: [Errno 13] Keine Berechtigung: '/home/carsten/.qgis2//processing'
>> Python-Version:
>> 2.7.3 (default, Sep 26 2013, 20:26:19)
>> [GCC 4.6.3]
>> QGIS-Version:
>> 2.0.1-Dufour Dufour, exported
>> Python-Pfad: ['/usr/share/qgis/python/plugins/processing',
>> '/usr/share/qgis/python', '/home/carsten/.qgis2/python',
>> '/home/carsten/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
>> '/usr/local/lib/python2.7/dist-packages/OWSLib-0.7.2-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/pytz-2012j-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/python_dateutil-2.1-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/six-1.3.0-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/Iris-1.4.0-py2.7-linux-i686.egg',
>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
>> '/usr/local/lib/python2.7/site-packages/grib_api',
>> '/usr/local/lib/python2.7/dist-packages/setuptools-0.6c11-py2.7.egg-info',
>> '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
>> Does anyone has an idea to solve this?
>> Thanks a lot
>> Carsten
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20131015/6f4875ed/attachment-0001.html>
More information about the Live-demo mailing list
