[Live-demo] [OSGeo] #1348: tilemill: failure to install on ubu 14.04 from ppa due to missing init.d script
OSGeo trac_osgeo at osgeo.org
Sun Aug 10 14:59:50 PDT 2014
script
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:  tilemill
Changes (by hamish):
 * cc: springmeyer (added)
Comment:
 here is the problematic section of the
 /var/lib/dpkg/info/tilemill.postinst script:
 # Automatically added by dh_installinit
 if [ -x "/etc/init.d/tilemill" ] || [ -e "/etc/init/tilemill.conf" ]; then
         if [ ! -e "/etc/init/tilemill.conf" ]; then
                 update-rc.d tilemill defaults >/dev/null
         fi
         invoke-rc.d tilemill start || exit $?
 fi
 # End automatically added section
 update-rc.d -f tilemill remove >/dev/null || exit $?
 changing the `exit $?` to `exit 0` will allow it to get past, probably we
 have to try to install it, let it break, patch the above file, then try
 again with 'apt-get -f install'. I'm not sure why/if it needs to actually
 run it at install time, and what doesn't get done if it doesn't happen.
 note classic /etc/init.d/tilemill does not exist, but
 /etc/init/tilemill.conf does.
 maybe if we just do `service tilemill start && service tilemill stop` at
 the end of the install script it will pick up whatever the code snippet
 above is trying to do?
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1348#comment:4>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
