[Live-demo] Packaging and project re-organization
Alex Mandel
tech_dev at wildintellect.com
Thu Jan 2 13:49:59 PST 2014
On 01/02/2014 12:37 PM, James Klassen wrote:
> On 2013/12/31 4:18 PM, Alex Mandel wrote:
>> Keep in mind that our installation method does double duty, not only
>> installing an application but also as a guide for how to install such an
>> application (I use the postgis script all the time for this). So
>> inventing a new way to install applications that is not the norm for a
>> known project needs to be easier and better than the current common method.
> This is the biggest hurdle I am facing with packaging GeoMoose as a .deb.
> As GeoMoose is primarily HTML/JS and some PHP, there is nothing to
> build. There is some advantage to listing dependencies of the various
> components in a .deb. The demo app provides a working example of how
> all these pieces (plus external dependencies such as MapServer and
> Apache) can be used together with some example data. My trouble is that
> this is just one way the pieces can be used to build a whole. For
> example, using Nginx instead of Apache or using something other than
> MapServer to serve WMS.
> The demo is important to our users because many of them want to start
> with something that works and incrementally substitute in their data.
> Thus, the way people typically install GeoMoose is to install the demo
> as a base (.zip or more ideally clone from GitHub) and start
> configuring/customizing to their liking. It is typical to have multiple
> GeoMoose instances (possibly of differing versions) on one server. The
> install_geomoose.sh script as is does a good job of documenting general
> steps someone could follow to install GeoMoose on any Un*x style machine
> (assuming they can manually translate "apt-get install" to the local
> package manager). For the casual user, a .deb is much more opaque in
> terms of understanding what is going on.
Well so you do need a webserver with php modules installed. That is a
good use of the control file. So you can put a required Apache or Nginx
(whichever listed first is the preferred if neither are present. Then if
you put Mapserver in the Recommends I think Ubuntu would automatically
install it but allow for mapserver to be removed without removing geomoose.
The package could also include or pull a second package which is the
demo instance.
FYI, deb file sources do contain the Post Install script which would
look almost the same as the current install script.
Thanks,
Alex
More information about the Live-demo
