[Live-demo] [OSGeo] #1279: PostgreSQL 9.3 template encoding
OSGeo
trac_osgeo at osgeo.org
Tue Jan 14 02:24:37 PST 2014
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: blocker | Milestone: OSGeoLive7.9
Component: LiveDVD | Keywords:
Removing obsolete dictionary files:
* No PostgreSQL clusters exist; see "man pg_createcluster"
Setting up postgresql-9.3 (9.3.2-1.pgdg12.4+1~precise) ...
Creating new cluster 9.3/main ...
config /etc/postgresql/9.3/main
data /var/lib/postgresql/9.3/main
locale C
port 5432
update-alternatives: using
/usr/share/postgresql/9.3/man/man1/postmaster.1.gz to provide
/usr/share/man/man1/postmaster.1.gz (postmaster.1.gz) in auto mode.
* Starting PostgreSQL 9.3 database server
...done.
and then:
Processing triggers for menu ...
ALTER ROLE
createdb: database creation failed: ERROR: new encoding (UTF8) is
incompatible with the encoding of the template database (SQL_ASCII)
HINT: Use the same encoding as in the template database, or use template0
as template.
psql: FATAL: database "user" does not exist
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1279>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
