[Live-demo] [OSGeo] #1362: Ubuntu updates break build process
OSGeo trac_osgeo at osgeo.org
Tue Jul 1 09:35:47 PDT 2014
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:
 Hi all,
 It is 4 days now that the nightly build is failing. At first I thought it
 was a network problem. After testing on the backup build server though,
 this problem is reproduced on both systems...
 Reason of failure: System updates (again......)
 Build 11530 was OK. Failure started on build 11531 and forward.
 Between those 2 revisions, no changes happened to the OSGeoLive folder.
 From the build log:
 total 4460
 -rw------- 1 root root 2685850 Apr 10 20:23 System.map-3.13.0-24-generic
 -rw-r--r-- 1 root root 1162233 Apr 10 20:23 abi-3.13.0-24-generic
 -rw-r--r-- 1 root root  169631 Apr 10 20:23 config-3.13.0-24-generic
 drwxr-xr-x 2 root root    4096 Apr 16 19:36 grub
 -rw-r--r-- 1 root root  176500 Mar 12 12:31 memtest86+.bin
 -rw-r--r-- 1 root root  178176 Mar 12 12:31 memtest86+.elf
 -rw-r--r-- 1 root root  178680 Mar 12 12:31 memtest86+_multiboot.bin
 update-initramfs: Generating /boot/initrd.img-3.13.0-24-generic
 cryptsetup: WARNING: could not determine root device from /etc/fstab
 total 31348
 -rw-r--r-- 1 root root 27530521 Jun 26 19:49 initrd.img-3.13.0-24-generic
 Ign http://archive.ubuntu.com trusty InRelease
 Ign http://security.ubuntu.com trusty-security InRelease
 Ign http://archive.ubuntu.com trusty-updates InRelease
 Get:1 http://security.ubuntu.com trusty-security Release.gpg [933 B]
 Get:2 http://archive.ubuntu.com trusty Release.gpg [933 B]
 Get:3 http://security.ubuntu.com trusty-security Release [58.5 kB]
 Get:4 http://archive.ubuntu.com trusty-updates Release.gpg [933 B]
 Get:5 http://archive.ubuntu.com trusty Release [58.5 kB]
 Get:6 http://security.ubuntu.com trusty-security/main i386 Packages [101
 kB]
 Get:7 http://archive.ubuntu.com trusty-updates Release [58.5 kB]
 Get:8 http://archive.ubuntu.com trusty/main i386 Packages [1348 kB]
 Get:9 http://security.ubuntu.com trusty-security/restricted i386 Packages
 [14 B]
 Get:10 http://security.ubuntu.com trusty-security/universe i386 Packages
 [34.8 kB]
 Get:11 http://security.ubuntu.com trusty-security/multiverse i386 Packages
 [1392 B]
 Get:12 http://security.ubuntu.com trusty-security/main Translation-en
 [49.1 kB]
 Get:13 http://security.ubuntu.com trusty-security/multiverse Translation-
 en [587 B]
 Get:14 http://security.ubuntu.com trusty-security/restricted Translation-
 en [14 B]
 Get:15 http://security.ubuntu.com trusty-security/universe Translation-en
 [18.9 kB]
 Get:16 http://archive.ubuntu.com trusty/restricted i386 Packages [13.4 kB]
 Get:17 http://archive.ubuntu.com trusty/universe i386 Packages [5866 kB]
 Get:18 http://archive.ubuntu.com trusty/multiverse i386 Packages [134 kB]
 Hit http://archive.ubuntu.com trusty/main Translation-en
 Hit http://archive.ubuntu.com trusty/multiverse Translation-en
 Hit http://archive.ubuntu.com trusty/restricted Translation-en
 Get:19 http://archive.ubuntu.com trusty/universe Translation-en [4089 kB]
 Get:20 http://archive.ubuntu.com trusty-updates/main i386 Packages [202
 kB]
 Get:21 http://archive.ubuntu.com trusty-updates/restricted i386 Packages
 [14 B]
 Get:22 http://archive.ubuntu.com trusty-updates/universe i386 Packages
 [138 kB]
 Get:23 http://archive.ubuntu.com trusty-updates/multiverse i386 Packages
 [7569 B]
 Get:24 http://archive.ubuntu.com trusty-updates/main Translation-en [92.1
 kB]
 Get:25 http://archive.ubuntu.com trusty-updates/multiverse Translation-en
 [3971 B]
 Get:26 http://archive.ubuntu.com trusty-updates/restricted Translation-en
 [14 B]
 Get:27 http://archive.ubuntu.com trusty-updates/universe Translation-en
 [66.9 kB]
 Fetched 12.3 MB in 13s (934 kB/s)
 Reading package lists...
 systemd-logind: unrecognized service
 Building dependency tree...
 Reading state information...
 The following extra packages will be installed:
   libpam-systemd libsystemd-daemon0
 Suggested packages:
   cgmanager
 The following packages will be upgraded:
   libpam-systemd libsystemd-daemon0 systemd-services
 3 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
 Need to get 232 kB of archives.
 After this operation, 5120 B of additional disk space will be used.
 Get:1 http://archive.ubuntu.com/ubuntu/ trusty-updates/main libpam-systemd
 i386 204-5ubuntu20.2 [25.2 kB]
 Get:2 http://archive.ubuntu.com/ubuntu/ trusty-updates/main systemd-
 services i386 204-5ubuntu20.2 [197 kB]
 Get:3 http://archive.ubuntu.com/ubuntu/ trusty-updates/main libsystemd-
 daemon0 i386 204-5ubuntu20.2 [9790 B]
 Fetched 232 kB in 0s (330 kB/s)
 (Reading database ... 113986 files and directories currently installed.)
 Preparing to unpack .../libpam-systemd_204-5ubuntu20.2_i386.deb ...
 invoke-rc.d: unknown initscript, /etc/init.d/systemd-logind not found.
 Unpacking libpam-systemd:i386 (204-5ubuntu20.2) over (204-5ubuntu20) ...
 Preparing to unpack .../systemd-services_204-5ubuntu20.2_i386.deb ...
 Unpacking systemd-services (204-5ubuntu20.2) over (204-5ubuntu20) ...
 Preparing to unpack .../libsystemd-daemon0_204-5ubuntu20.2_i386.deb ...
 Unpacking libsystemd-daemon0:i386 (204-5ubuntu20.2) over (204-5ubuntu20)
 Processing triggers for man-db (2.6.7.1-1) ...
 Processing triggers for ureadahead (0.100.0-16) ...
 Setting up libsystemd-daemon0:i386 (204-5ubuntu20.2) ...
 Setting up systemd-services (204-5ubuntu20.2) ...
 Installing new version of config file /etc/systemd/logind.conf ...
 Setting up libpam-systemd:i386 (204-5ubuntu20.2) ...
 dpkg: error processing package libpam-systemd:i386 (--configure):
  subprocess installed post-installation script returned error exit status
 100
 Processing triggers for libc-bin (2.19-0ubuntu6) ...
 Errors were encountered while processing:
  libpam-systemd:i386
 E: Sub-process /usr/bin/dpkg returned an error code (1)
 libpam-systemd is already the newest version.
 0 upgraded, 0 newly installed, 0 to remove and 177 not upgraded.
 1 not fully installed or removed.
 After this operation, 0 B of additional disk space will be used.
 The following packages will be REMOVED:
   libwhoopsie0 lubuntu-desktop whoopsie
 0 upgraded, 0 newly installed, 3 to remove and 175 not upgraded.
 After this operation, 193 kB disk space will be freed.
 Removing lubuntu-desktop (0.55) ...
 Removing whoopsie (0.2.24.5) ...
 invoke-rc.d: unknown initscript, /etc/init.d/whoopsie not found.
 Removing libwhoopsie0 (0.2.24.5) ...
 And after a few lines:
 Processing triggers for libglib2.0-0:i386 (2.40.0-2) ...
 Processing triggers for hicolor-icon-theme (0.13-1) ...
 Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
 Processing triggers for mime-support (3.54ubuntu1) ...
 Processing triggers for gconf2 (3.2.6-0ubuntu2) ...
 (gconftool-2:24136): GConf-WARNING **: Client failed to connect to the
 D-BUS daemon:
 Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
 Processing triggers for lubuntu-software-center (0.0.8-0ubuntu1) ...
 Creating package database in /var/cache/lsc_packages.db
 Reading package lists... 0%
 Reading package lists... 8%
 Reading package lists... Done
 Building dependency tree... 0%
 Building dependency tree... 50%
 Building dependency tree... 83%
 Reading state information... 0%
 Reading state information... Done
 dia-gnome-gnome: package not found
 dia-gnomenara: package not found
 gstreamer0.10-ffmpeg: package not found
 dia-gnomeler-app: package not found
 magicicada: package not found
 xnetcardconfig: package not found
 insanity-tools: package not found
 prefixsuffix: package not found
 ubuntuone-control-panel-qt: package not found
 nvidia-96: package not found
 gnome-utils: package not found
 bokken: package not found
 edubuntu-desktop-kde: package not found
 maitreya: package not found
 arkose-gui: package not found
 kita2: package not found
 idle-python3.3: package not found
 atris: package not found
 kradioripper: package not found
 rdsconsole: package not found
 vavoom: package not found
 abuse: package not found
 Network fails completely, leading to a broken build:
 Processing triggers for initramfs-tools (0.103ubuntu4.2) ...
 Executing: gpg --ignore-time-conflict --no-options --no-default-keyring
 --homedir /tmp/tmp.0Czuf7IsyC --no-auto-check-trustdb --trust-model always
 --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg
 --keyserver keyserver.ubuntu.com --recv-keys FADA29F7
 gpg: requesting key FADA29F7 from hkp server keyserver.ubuntu.com
 ?: keyserver.ubuntu.com: Host not found
 gpgkeys: HTTP fetch error 7: couldn't connect: Connection refused
 gpg: no valid OpenPGP data found.
 gpg: Total number processed: 0
 Err http://archive.ubuntu.com trusty InRelease
 Err http://archive.ubuntu.com trusty-updates InRelease
 Err http://ppa.launchpad.net trusty InRelease
 Err http://security.ubuntu.com trusty-security InRelease
 Err http://ppa.launchpad.net trusty Release.gpg
   Could not resolve 'ppa.launchpad.net'
 Err http://archive.ubuntu.com trusty Release.gpg
   Could not resolve 'archive.ubuntu.com'
 Err http://security.ubuntu.com trusty-security Release.gpg
   Could not resolve 'security.ubuntu.com'
 Err http://archive.ubuntu.com trusty-updates Release.gpg
 W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/InRelease
 W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/trusty-
 security/InRelease
 W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty-
 updates/InRelease
 W: Failed to fetch
 http://ppa.launchpad.net/osgeolive/nightly/ubuntu/dists/trusty/InRelease
 W: Failed to fetch
 http://archive.ubuntu.com/ubuntu/dists/trusty/Release.gpg  Could not
 updates/Release.gpg  Could not resolve 'archive.ubuntu.com'
 W: Failed to fetch
 http://ppa.launchpad.net/osgeolive/nightly/ubuntu/dists/trusty/Release.gpg
 security/Release.gpg  Could not resolve 'security.ubuntu.com'
 W: Some index files failed to download. They have been ignored, or old
 ones used instead.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1362>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
