[Live-demo] [OSGeo] #1362: Ubuntu updates break build process
    OSGeo
    trac_osgeo at osgeo.org
    Sat Jul  5 04:33:18 PDT 2014
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:  iheartubuntu
Comment(by hamish):
 putting it on hold should be ok, we should probably take it off hold but
 not upgrade at the end of the script?
 the latest build log shows that /run/resolvconf/resolv.conf does not
 change, and is always set as:
 # Dynamic resolv.conf(5) file for glibc resolver(3) generated by
 resolvconf(8)
 #     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
 So I wonder how the DNS is working in the chroot even from the start? and
 what does the upgrade of the resolvconf package do to make that stop? and
 if we simply run resolvconf(8) if it will generate a new/temporary one?
 Probably not needed now, but another workaround could be to just set
 /etc/resolv.conf's nameserver to 8.8.8.8 manually for the duration of the
 build.
 still a mystery,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1362#comment:11>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
