[Live-demo] [OSGeo] #1355: Iris fails to build in 14.04
OSGeo trac_osgeo at osgeo.org
Wed Jul 30 04:58:06 PDT 2014
 Reporter:  kalxas    |        Owner:  live-demo@…
     Type:  defect    |       Status:  reopened
 Priority:  critical  |    Milestone:  OSGeoLive8.0
Component:  LiveDVD   |   Resolution:
 Keywords:            |
Comment(by kalxas):
 Started Iris debian package but I am getting this error:
 https://launchpadlibrarian.net/181056516/buildlog_ubuntu-
 trusty-i386.iris_1.6.1-0~trusty1_FAILEDTOBUILD.txt.gz
 copying
 lib/iris/tests/results/cube_collapsed/latitude_time_dual_stage.data.0.npy
 -> build/lib.linux-i686-2.7/iris/tests/results/cube_collapsed
 copying lib/iris/fileformats/_pyke_rules/fc_rules_cf.krb ->
 build/lib.linux-i686-2.7/iris/fileformats/_pyke_rules
 copying lib/iris/tests/stock_mdi_arrays.npz ->
 copying lib/iris/tests/stock_arrays.npz ->
 /usr/bin/python tools/generate_std_names.py etc/cf-standard-name-table.xml
 build/lib.linux-i686-2.7/iris/std_names.py
   File "setup.py", line 252, in <module>
     'std_names': MakeStdNames, 'pyke_rules': MakePykeRules},
   File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
     dist.run_commands()
   File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
     self.run_command(cmd)
   File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
     cmd_obj.run()
   File "/usr/lib/python2.7/distutils/command/build.py", line 128, in run
     self.run_command(cmd_name)
   File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
     self.distribution.run_command(command)
     cmd_obj.run()
   File "setup.py", line 217, in run
     MakePykeRules._pyke_rule_compile()
   File "setup.py", line 170, in _pyke_rule_compile
     import iris.fileformats._pyke_rules
   File "build/lib.linux-i686-2.7/iris/__init__.py", line 107, in <module>
     import iris.cube
   File "build/lib.linux-i686-2.7/iris/cube.py", line 35, in <module>
     import iris.analysis
   File "build/lib.linux-i686-2.7/iris/analysis/__init__.py", line 41, in
 <module>
     import iris.coords
   File "build/lib.linux-i686-2.7/iris/coords.py", line 31, in <module>
     import netcdftime
 ImportError: No module named netcdftime
 dh_auto_build: python setup.py build --force returned exit code 1
 make: *** [build] Error 1
 dpkg-buildpackage: error: debian/rules build gave error exit status 2
 Build finished at 20140730-1154
 FAILED [dpkg-buildpackage died]
 Thoughts?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1355#comment:6>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
