[Live-demo] Installing osgeo-live-vm-7.9.7z with Oracle VirtualBox
Alex Mandel tech_dev at wildintellect.com
Sat Jun 7 10:27:01 PDT 2014
I actually updated the svn version of the instructions last month to add
that apt-get update is required before any packages can be upgraded and
that in the event that linux-headers-generic run at the wrong time can
actually pull the wrong headers. An update and reboot should work before
adding the guest additions.
I should probably push those edits to the online version.
Thanks,
Alex
On 06/07/2014 07:33 AM, Richard Thomas wrote:
> Problem for me when trying to run the following line from the quickstart
> instructions:
>     user at osgeolive:~$ sudo apt-get install build-essential
> during an installation of osgeo-live-vm-7.9.7z VM (downloaded today)
> with VirtualBox (downloaded 2 days ago). I tried to carefully follow the
> steps on:
> http://live.osgeo.org/en/quickstart/virtualization_quickstart.html
> The solution I found was to ensure that the XUbuntu was fully updated
> before executing the line above. Although its all working now, the
> initial errors were as follows:
> user at osgeolive:~/Desktop$ sudo apt-get install build-essential
> [sudo] password for user:
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> The following extra packages will be installed:
>   dpkg-dev libdpkg-perl linux-headers-3.2.0-60
> linux-headers-3.2.0-60-generic
> Suggested packages:
>   debian-keyring
> Recommended packages:
>   libalgorithm-merge-perl
> The following NEW packages will be installed
>   build-essential dpkg-dev libdpkg-perl linux-headers-3.2.0-60
>   linux-headers-3.2.0-60-generic linux-headers-generic
> 0 to upgrade, 6 to newly install, 0 to remove and 0 not to upgrade.
> Need to get 13.3 MB of archives.
> After this operation, 70.2 MB of additional disk space will be used.
> Do you want to continue [Y/n]? y
> Err http://us.archive.ubuntu.com/ubuntu/ precise-updates/main
> libdpkg-perl all 1.16.1.2ubuntu7.2
>   404  Not Found [IP: 91.189.91.15 80]
> Err http://us.archive.ubuntu.com/ubuntu/ precise-updates/main dpkg-dev
> Get:1 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main
> build-essential i386 11.5ubuntu2.1 [5,796 B]
> Get:2 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main
> linux-headers-3.2.0-60 all 3.2.0-60.91 [11.7 MB]
> Get:3 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main
> linux-headers-3.2.0-60-generic i386 3.2.0-60.91 [976 kB]
> linux-headers-generic i386 3.2.0.60.71
> Err http://security.ubuntu.com/ubuntu/ precise-security/main
>   404  Not Found [IP: 91.189.91.14 80]
> Fetched 12.7 MB in 29s (424 kB/s)
> Failed to fetch
> http://us.archive.ubuntu.com/ubuntu/pool/main/d/dpkg/libdpkg-perl_1.16.1.2ubuntu7.2_all.deb
> Failed to fetch
> http://us.archive.ubuntu.com/ubuntu/pool/main/d/dpkg/dpkg-dev_1.16.1.2ubuntu7.2_all.deb
> Failed to fetch
> http://security.ubuntu.com/ubuntu/pool/main/l/linux-meta/linux-headers-generic_3.2.0.60.71_i386.deb
> E: Unable to fetch some archives, maybe run apt-get update or try with
> --fix-missing?
> If other people are likely to have the same problem, it might be worth
> adding a note to the quickstart web page with the appropriate command
> line instructions to perform the update (I just responded to the
> unsolicited prompt from the OS a few minutes later to do some updates).
> Richard
> P.S. nice work in providing a pre-built VM image with lots of GIS
> goodies pre-installed. Having just built a separate Linux VM from an ISO
> file and started to install other packages I appreciate the efforts saved!
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
