[Live-demo] [Ubuntu] .war -> .deb packaging
Matthias Streulens Geomajas
matthias.streulens at geomajas.org
Mon Jun 9 13:48:35 PDT 2014
Yeah, there we are! sudo apt-get install geomajas ?
I'm thinking already a year of that feature...
But we are not providing war files (jetty-runner). If it is needed, we
can provide a war file.
Is assistance of packaging of our project for osgeolive needed?
Kind regards,
Matthias Streulens
System Admin Geomajas Community
Cameron Shorter schreef op 2014-06-09 22:28:
> ubuntu-gis community,
> We, the osgeolive community, wish to improve packaging of java
> projects on osgeolive, by developing .deb packages, but we are short
> on expertise on how to make this happen.
> As below, Jerome has recommended that as a start we extend existing
> .war packages to .deb packages, and have this role into ubuntugis. To
> me, this sounds reasonable. Are there any objections or suggestions
> related to this proposal?
> Jerome, Ben, others,
> Is there a howto or similar that we can reference, to guide projects
> in the best practices for converting .war->.deb? I'd like to add a
> section to our osgeolive processes, and link to it from ~
> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#.deb_Packaging
> On 9/06/2014 10:01 pm, Jerome Villeneuve Larouche wrote:
>> Hi,
>> Thanks for the tip! I'll take a look.
>> For GeoServer those were things I found when I looked into it last
>> year, but since I had no experience on how GeoServer buillt and work,
>> I didn't really get it to work. Your expertise will be pretty valuable
>> for this package this year!
>> And off course the .war -> .deb is simply a quick workaround to try to
>> have some packages ready for OsgeoLive and a way to at least have some
>> Java packages available.
>> Jerome
>> On 14-06-08 10:15 PM, Ben Caradoc-Davies wrote:
>>> Hi Jérôme,
>>> have you looked at how Debian packages such as tomcat7-admin handle
>>> packing servlets? Even if you are not yet in a position to adopt
>>> their patterns, it would help to inform your approach.
>>> One other problem is GeoServer contains some non-free drivers such as
>>> the Oracle ojdbc14.jar that is bundled with the Oracle plugin. Debian
>>> will require this to be in non-free. Or you could bundle one without
>>> ojdbc14.jar and have a script download it (similar tricks are used to
>>> install flash). ArcSDE also contains non-free drivers. MS SQL drivers
>>> have to be obtained by the user (or at least they were; need to
>>> check).
>>> Also, some deployments require JDBC drivers at the tomcat level for
>>> JNDI connection pooling between servletss, and having duplicate
>>> drivers on the classpath can result in Bad Things Happening. The
>>> right way to do with with Debian will be with cunning use of .deb
>>> Conflicts.
>>> I am happy for you to go ahead with the simple .war to .deb
>>> conversion as you have described; once this is working a detailed
>>> translation to .deb is a future work.
>>> Kind regards,
>>> Ben.
>>> On 08/06/14 23:31, Jerome Villeneuve Larouche wrote:
>>>> I've also participated in the OsgeoLive meeting this week and talked
>>>> a
>>>> bit about my plans for Java packages. We're thinking of going for a
>>>> quick packaging way first by packaging .war to .deb. It won't be
>>>> accepted on Debian, but for OsgeoLive and UbuntuGIS it would be a
>>>> quick
>>>> hack to have the packages available. If you have any suggestion or
>>>> idea
>>>> about that, I would be glad to hear them.
More information about the Live-demo
