[Live-demo] [OSGeo] #1355: Iris fails to build in 14.04
OSGeo
trac_osgeo at osgeo.org
Tue Jun 17 08:46:00 PDT 2014
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive8.0
Component: LiveDVD | Keywords:
/usr/bin/python tools/generate_std_names.py etc/cf-standard-name-table.xml
build/lib.linux-i686-2.7/iris/std_names.py
File "setup.py", line 237, in <module>
'std_names': MakeStdNames, 'pyke_rules': MakePykeRules},
File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/usr/lib/python2.7/distutils/command/install.py", line 601, in run
self.run_command('build')
File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/lib/python2.7/distutils/command/build.py", line 128, in run
self.run_command(cmd_name)
cmd_obj.run()
File "setup.py", line 202, in run
MakePykeRules._pyke_rule_compile()
File "setup.py", line 155, in _pyke_rule_compile
import iris.fileformats._pyke_rules
File "build/lib.linux-i686-2.7/iris/__init__.py", line 106, in <module>
import iris.cube
File "build/lib.linux-i686-2.7/iris/cube.py", line 35, in <module>
import iris.analysis
File "build/lib.linux-i686-2.7/iris/analysis/__init__.py", line 38, in
<module>
import iris.coords
File "build/lib.linux-i686-2.7/iris/coords.py", line 33, in <module>
import iris.aux_factory
File "build/lib.linux-i686-2.7/iris/aux_factory.py", line 28, in
<module>
from iris._cube_coord_common import CFVariableMixin
File "build/lib.linux-i686-2.7/iris/_cube_coord_common.py", line 24, in
<module>
import iris.unit
File "build/lib.linux-i686-2.7/iris/unit.py", line 34, in <module>
import netcdftime
ImportError: No module named netcdftime
touch: cannot touch '/usr/local/lib/python2.7/dist-
packages/Iris-1.4.0-py2.7-linux-i686.egg/iris/fileformats/_pyke_rules/compiled_krb/*':
No such file or directory
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1355>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
