[Live-demo] Testing 16 GB+ full install idea
    Cameron Shorter
    cameron.shorter at gmail.com
    Mon Sep  1 15:41:47 PDT 2014
Hi Alex,
This is very useful information which probably should be included in our
USB quickstart:
http://adhoc.osgeo.osuosl.org/livedvd/docs/en/quickstart/usb_quickstart.html
Or if not ready for production, it can be put into our wiki at:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Quick_Start_for_USB
On 2/09/2014 3:57 am, Alex Mandel wrote:
> Just a few notes on something we discussed in IRC.
> Hamish and I discussed in IRC that once you have a 16 GB drive or bigger
> it might make sense to simply do a regular hard drive style install as
> opposed to a squashfs type system the DVD or current bootable USB uses.
> I can verify as expected, this method works. It is a little dangerous to
> do, in that one mistake in the drive assignment section could wipe your
> existing hard drive. My recommendation is to disconnect your real hard
> drive before doing the install.
> It appears to be persistent without the performance penalty of a
> persistent bootable drive. Long term I'm not sure if there will be
> negative effects of /tmp writing to the drive as opposed to be cached
> somewhere in ram. My suggestion is that when formatting leave 5-10% of
> your usb stick unallocated. At least with SSDs this allows the drive
> firmware to remap the unallocated bits to replace bad blocks when needed.
> As others have pointed out the move to USB 3 drive in the next year
> should greatly increase performance also, for those users that have USB
> 3 connectors. Some USB 2 users may also benefit too from better drives
> that can actually max the USB 2 speeds.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20140902/f19abdba/attachment.html>
More information about the Live-demo
