[Live-demo] ISO not isohybrid, lacks UEFI support
Ben Caradoc-Davies ben at transient.nz
Mon Dec 5 10:25:08 PST 2016
Cameron,
I expect that the additional boot equipment will increase the size of
the ISO by a only a small amount. Do we need to add these packages to
the final ISO? I will test and report back.
Kind regards,
Ben.
On 04/12/16 22:12, Cameron Shorter wrote:
> Hi Ben,
> Your proposal sounds like a good idea, although I have to confess that I
> don't know enough about building USBs contribute in a meaningful way to
> the discussion.
> Are you able to confirm that adding these extra packages will not add
> much size to the final OSGeo-Live ISO?
> And that there is not likely to be any adverse side effects by the
> additions?
> I'd be interested to hear if Angelos has an opinion on this.
> Warm regards, Cameron
> On 2/12/2016 10:16 AM, Ben Caradoc-Davies wrote:
>> The current ISO image osgeo-live-10.0-amd64.iso is not isohybrid, and
>> lacks UEFI support. As far as I know, all current official Ubuntu live
>> images have both. Shipping isohybrid images simplifies USB thumb drive
>> creation because the ISO can then be written directly to a raw device
>> with dd without needing any other processing, not to mention
>> consistency with Ubuntu.
>> Does anyone object to changing the ISO build process to make isohybrid
>> images with UEFI support? This should a matter of a few additional
>> xorriso arguments.
>> The current ISO is suitable for MBR isohybrid but lacks UEFI support:
>> $ isohybrid -u osgeo-live-10.0-amd64.iso
>> isohybrid: osgeo-live-10.0-amd64.iso: unable to find efi image
>> The existing boot equipment of the ISO contains only MBR support:
>> $ xorriso -indev osgeo-live-10.0-amd64.iso -report_el_torito plain
>> -report_system_area plain
>> xorriso 1.4.6 : RockRidge filesystem manipulator, libburnia project.
>> xorriso : NOTE : Loading ISO image tree from LBA 0
>> xorriso : UPDATE : 502 nodes read in 1 seconds
>> xorriso : NOTE : Detected El-Torito boot information which currently
>> is set to be discarded
>> Drive current: -indev 'osgeo-live-10.0-amd64.iso'
>> Media current: stdio file, overwriteable
>> Media status : is written , is appendable
>> Boot record  : El Torito
>> Media summary: 1 session, 2062470 data blocks, 4028m data, 8267m free
>> Volume id    : 'OSGEOLIVE10'
>> El Torito catalog  : 164  1
>> El Torito cat path : /isolinux/boot.cat
>> El Torito images   :   N  Pltf  B   Emul  Ld_seg  Hdpt Ldsiz         LBA
>> El Torito boot img :   1  BIOS  y   none  0x0000  0x00 4         165
>> El Torito img path :   1  /isolinux/isolinux.bin
>> El Torito img opts :   1  boot-info-table isohybrid-suitable
>> xorriso : NOTE : No System Area was loaded
>> Kind regards,
Ben Caradoc-Davies <ben at transient.nz>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
More information about the Live-demo mailing list
