[Live-demo] Permissions problems with GeoServer
    Angelos Tzotsos
    gcpp.kalxas at gmail.com
    Tue Dec  6 10:47:35 PST 2016
I figured out what went wrong.
The Cartaro installer used to set GeoServer data folder permissions
before, so now that Cartaro was retired, this code is missing:
https://github.com/OSGeo/OSGeoLive/blob/master/bin/retired/install_cartaro.sh#L381-L385
Lets add this to the GeoNode installer, since that one is
starting/stopping GeoServer for the first time during build.
Thoughts?
On 12/06/2016 12:02 PM, Angelos Tzotsos wrote:
> Hi Ben,
> I saw the same issue in nightly build5.
> I am wondering why geoserver has this permission issue, previous
> versions used to work fine with this setup.
> Best,
> Angelos
> On 12/06/2016 05:10 AM, Ben Caradoc-Davies wrote:
>> Angelos,
>> even with my most recent fixes
>> <https://github.com/bencaradocdavies/OSGeoLive/tree/upgrade-geoserver>,
>> GeoServer on a nightly build will still not start.
>> Looks to me like permissions problems (files and directories in the
>> data directory whcih are owned by root). Likely culprit is
>> install_geonode.sh, which starts GeoServer as root "to update layers
>> in the geonode db", causing the creation of files and directories
>> owned by root:root. The solution (in install_geonode.sh) might be
>> something like:
>> su -c "$GEOSERVER_PATH/bin/startup.sh" - user
>> but it will take a little fiddling to get this working with
>> redirection and running in the background. I will let you know when I
>> have a fix.
>> Kind regards,
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
More information about the Live-demo
