[Live-demo] IPython 4.0.0 and Jupyter ppa
Angelos Tzotsos
gcpp.kalxas at gmail.com
Mon Feb 1 03:12:59 PST 2016
Hi all,
After some debugging (thanks Brian and Massimo), the Jupyter and IPython
packages are working fine.
In case you want to test, there is a new build available:
http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build58-amd64-b81d61d.iso
http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/9.5nightly/osgeo-live-nightly-build58-amd64-b81d61d.iso
I will merge the pull request and then we can work on the ipython
installer for the remaining details (launchers, converted notebooks etc).
We also need to make a plan integrating Massimo's work from GSoC 2015,
which has to be re-based to the new setup.
Happy hacking,
Angelos
On 01/27/2016 04:41 PM, Angelos Tzotsos wrote:
> Hi all,
> I have prepared a ppa to include all the Jupyter and IPython libraries
> that are pulled when someone does "pip install jupyter"
> https://launchpad.net/~gcpp-kalxas/+archive/ubuntu/jupyter
> I have a local git branch including the apt-get install command to get
> those libraries in the system:
> https://github.com/kalxas/OSGeoLive/commit/48292e078b2bace861dffbe3310ddfdde05ce078
> Based on the above commit, I have prepared a nightly build:
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-nightly-build32-amd64-48292e0.iso
> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/gisvm/9.5nightly/osgeo-live-nightly-build32-amd64-48292e0.iso
> We need a volunteer to check for any missing libraries and complete
> the missing installation parts so that the notebook works again as
> expected.
> Cheers,
> Angelos
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
More information about the Live-demo
