[Live-demo] build remote
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Feb 17 11:18:26 PST 2016
Hi Brian,
There is no point to debug outside chroot.
As you can see in the rasdaman case, the new installer works fine
outside chroot, but causes trouble in chroot by creating a new system user:
https://github.com/OSGeo/OSGeoLive/pull/74#issuecomment-185346808
You have expressed your wish to not use GitHub and I respect that. You
have also expressed your wish not to reveal your personal git repository
(for security reasons) and you provided me the URL of your server to
pull from. I respect that too.
I have asked several times on IRC to send your pull requests via e-mail
on this mailing list, so that there is a time-stamp and an open thread
to review your changes (the same way every other pull request can be
commented on GitHub). And since the proposed changes have to be visible
on a public git repository for this review for everyone, I have offered
to host your branches on my public git repo.
Based on the above, regarding your changes in ipy-rename2 and
app-data-ipy-rename branches, I have created two public PRs to review:
https://github.com/OSGeo/OSGeoLive/pull/77
https://github.com/OSGeo/OSGeoLive/pull/78
Those changes happened a little while after I had opened PR76 (using IRC
log as a time-stamp), so I will evaluate PR76 first.
I also took the time to review your changes and I already merged some of
your changes in my PR:
https://github.com/kalxas/OSGeoLive/commit/c20cbab30de6e77f1b701a225dddcde5fd41bd99
Right now I am building a nightly based on PR76, which takes a long time
due to slow network (perhaps the glibc updates have caused this). If
there is a positive result, I will merge PR 76 and then we can evaluate
your pull request (new nightly builds and merge).
Best,
Angelos
On 02/17/2016 07:43 PM, Brian M Hamlin wrote:
> Hi Angelos -
>     as indicated in IRC ... my snapshot is LUbuntu 1404 amd64, with updates
>    I ran :   bootstrap, setup "nightly", install_services, install_java,
> install_tomcat, install_apache, ldconfig, updatedb -- FREEZE
> .. there might have seen some errors on bootstrap / setup
> but since I am not in chroot full setup, I moved on.. the most important thing
> is the content of /etc/apt/sources.lis.d and the keys
> (output pasted:   apt-key list   )
> running   install_jupyer.sh a second time shows no package errors..  missing
> apt-get update perhaps
>    so   http://SERVER:PORT/osgeolive_athens ipy-rename2
> has three changes to bin/install_jupyter.sh  and   git mv  app-data/ipython
>    app-data/jupyter
>    try accepting those changes and re-building, please
>      --Brian
> On Wed, 17 Feb 2016 18:27:57 +0200, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
>      Hi Brian,
>      I do not understand what you tried to do, did you try specific
>      installers or did you try to build an iso?
>      The iso build process is described here:
>      https://wiki.osgeo.org/wiki/Live_GIS_Build#How_to_do_development_.2F_debugging_with_the_current_build_method
>      The nightly from last night failed due to this PR:
>      which is leading to a broken login I have described in the PR discussion.
>      I am now building a new iso based only on the Jupyter PR:
>      https://github.com/OSGeo/OSGeoLive/pull/76
>      It seems that the glibc patching has affected part of the net and the
>      downloads are awfully slow today.
>      https://www.debian.org/security/2016/dsa-3481
>      The build process is taking forever.
>      Cheers,
>      Angelos
>      On 02/17/2016 03:31 AM, Brian M Hamlin wrote:
>       > Hi Angelos -
>       > I am eager to get the Jupyter things resolved.. I just attempted a build
>      here, but it fails regarding python packages.. there are conflicts unless
>      the apt sources are set carefully in a certain order.. So, in the interest
>      of time, I stopped. There is a new VM here with LUbuntu 1404, and minimal
>      setup as a snapshot, ready for further testing.
>       > Brian M Hamlin
>       > OSGeo California Chapter
>       > blog.light42.com
>       > _______________________________________________
>       > Live-demo mailing list
>       > Live-demo at lists.osgeo.org
>       > http://lists.osgeo.org/mailman/listinfo/live-demo
>       > http://live.osgeo.org
>       > http://wiki.osgeo.org/wiki/Live_GIS_Disc
>      Angelos Tzotsos, PhD
>      OSGeo Charter Member
>      http://users.ntua.gr/tzotsos
> Brian M Hamlin
> blog.light42.com
More information about the Live-demo mailing list
