[Live-demo] Submit new project - NASA WorldWind
    Brian M Hamlin
    maplabs at light42.com
    Fri Jan  8 14:30:06 PST 2016
+1 kalxas
On Fri, 8 Jan 2016 13:09:24 +0200, Angelos Tzotsos  wrote:
       Hi Cameron,
Given that we include at least another project that uses "trunk" (for
many years now) and not a released version, we cannot make this a hard
requirement in my opinion
Best,
Angelos
On Fri, Jan 8, 2016 at 7:52 AM, Cameron Shorter  wrote:
       Hi Gabriele,
Thanks for offering to help with reducing packaging size. That will be
helpful.
I also think it would be very valuable for the version of the World
Wind Web to be installed on OSGeo-Live to be allocated a version
number. There are many reasons for this, including:
1. People will be able to determine if the version of World Wind Web
they are looking at is the latest version.
2. People will be able to determine if they should upgrade to a more
recent version (because they are looking at an older version)
3. Developers and users will be able to align feature lists and bug
reports with specific version numbers, which will help users determine
whether to upgrade
I think that defining a package version number should be a prerequisite
for including the package on OSGeo-Live. The version number could be
called "beta" so long as it is considered "stable" by the developer and
user community.
Warm regards, Cameron
On 7/01/2016 2:22 am, Gabriele Prestifilippo wrote:
the Java version and the JavaScript’s one, are two different
applications, so we need to separate them.
I understand that the size of the Java might be a problem. I can try to
work a bit on it and delete the not strictly necessary files from the
original package, so to achieve a reasonable size.
Regarding the web version, I may ask Patrick about a tagged release,
even if now it seems to appear as ‘pre-release’ version.
Even though I want to reassure you that in spite of being not even a
beta, its usage was growing consistently in the past two years (as you
may see from the different projects developed), and no bugs were
reported. It is tagged in this way because not all the features
available in the Java version are yet available.
Best,
Gabriele.
Sent: mercoledì 6 gennaio 2016 14:32
To: Cameron Shorter; Gabriele Prestifilippo
Cc: live-demo at lists.osgeo.org
Subject: Re: [Live-demo] Submit new project - NASA WorldWind
Thank you Gabriele for the detailed responses.
I also strongly support the inclusion of Nasa World Wind in OSGeoLive.
Regarding the size of the installation, I would like to try a basic
installation first (without documentation to save some space) so we can
find out how much World Wind will compress in the iso. The next step
would be to try to use the data already present in the disk. Then we
will be able to make a decision regarding the amount of sample data
that will be needed.
Regarding Java vs Web version, personally I would like to see both included.
Having a tagged release is a good sign of stability, so I would prefer
to have a tagged version included. This would also help potential
packaging efforts.
Best,
Angelos
On Wed, Jan 6, 2016 at 2:24 PM, Cameron Shorter  wrote:
       Thanks Gabriele,
Based on your responses, it seems that Go World Wind is a mature,
established open source GIS product, which is in line with the
principles of OSGeo Live.
On the downsite, it appears to be a large product, which may be a
challenge to fit on OSGeo-Live. I'd be interested to hear thoughts from
Angelos and others in that regard.
The documentation does appear to be comprehensive and I feel shouldn't
be included with the OSGeo-Live release (it can be referenced). Instead
just provide standard OSGeo-Live Project Overview and Quickstart.
Also, I request you make use of existing OSGeo-Live sample data rather
that adding a new dataset. This reduces disk space and helps with
comparisons and integration between applications.
I'm undecided on whether World Wind Web is ready. I'd be hoping to see
a specific stable version nominated for inclusion.
It also seems to have a relatively new development history, so might
not have reached a stable release yet?
Would it make to bundle GeoWorldWind and WorldWindWeb together? Or are
they two stand alone applications?
On 6/01/2016 10:23 pm, Gabriele Prestifilippo wrote:
       Hi, I’m answering the questions referring to both versions.
If you consider including Java and Web version, I will provide two
different installation scripts.
I confirm that my contributions to OSGeo-Live will be compatible with
the OSGeo-Live license guidelines at the time of contribution
-What is its name?
Nasa World Wind, composed of Go World Wind and Web World Wind
- What is the home page URL?
http://goworldwind.org/ and http://webworldwind.org/
-Which OSI approved Open Source Licence is used?
NASA OPEN SOURCE AGREEMENT VERSION 1.3
(https://opensource.org/licenses/NASA-1.3)
-What does the application do and how does it add value to the
GeoSpatial stack of software?
World Wind provides a rich set of features for displaying and
interacting with geographic data and representing a wide range of
geometric objects using a 3d virtual globe
-Does the application make use of OGC standards? Which versions of the
standards? Client or server? You may wish to add comments about how
standards are used.
Yes, it uses on the client WMS, WFS and as GIS formats: Shapefile, KML,
VPF, GML, GeoJSON, GeoRSS, GPX, NMEA and many others to draw services
on the globe
-What language is it written in?
The Java version (goworldwind) is written mostly in java and C++, while
Web version is in Javascript
-Which version of the application should be included in the next
OSGeo-Live release?
World Wind Java SDK 2.0.0 and regarding the web version, it’s updated
frequently, so the latest one available during the disk build process.
- If risk adverse organisations have deployed your application into
production, it would imply that these organisations have verified the
stability of your software. Has the application been rolled out to
production into risk (ideally risk adverse) organisations? Please
mention some of these organisations?
US Federal Aviation Agency (FAA), US Department of Energy, US Air
Force, Army and Navy, US State Department, US Geological Survey,
European Space Agency, Politecnico di Milano at Como, Sweden Defence
Research Agency (FOI)
-What is the Open HUB URL for your project?
https://www.openhub.net/p/wwj and https://www.openhub.net/p/WebWorldWind
-What is the size of the user community? You can often answer this by
mentioning downloads, or describing a healthy, busy email list?
The US Government is our largest ‘formally recognized’ community,
with well over a 100,000 users. World Wind apps are a standard in
multiple US agencies. Additionally, the European Space Agency has
standardized on WebWorldWind for delivery of spatial data. The
www.WorldWindCentral.com forum has: Threads: 13,095;  Posts: 73,902;
Members: 32,080; Active Members: 90
-What is the size of your developer community?
Because applications using World Wind are many, especially throughout
the US Government, we cannot confirm the actual size of that community
but it is estimated to be in the hundreds.
-Do you have a bug free, stable release?
Yes, the latest stable version, 2.0.0 for the Java and the last in the
website for the Web’s one.
-Please discuss the level of testing that your project has gone through.
All versions of World Wind are tested before each release.
Additionally, feedback via the forum contribute to identification of
issues found by the open source community and these are addressed
accordingly.
-How long has the project has had mature code.
World Wind began as a .NET app in 2003 with some days in 2004 at
SourceForge (http://sourceforge.net/projects/nasa-exp/) of almost
100,000 downloads a day at ~250MB (including a base set of imagery and
elevation data for the world, the application was only a small fraction
of that). The Java version has been mature since late 200, the iOS
version since 2014 and the web version continues to mature, but has
been standardized on for use by the European Space Agency.
OSGeo-Live is targeted at applications that people can use rather than
libraries. Does the application have a user interface (possibly a
command line interface) that a user can interact with? (We do make an
exception for Incubated OSGeo Libraries, and will include Project
Overviews for these libraries, even if they don't have a user
interface.)
Yes, in both version it has a user interface to interact with the
globe, even though its main purpose is aimed to develop new
applications. It includes a lot of examples (with the proper source
code) to test all the features using a graphical user interface.
-We give preference to OSGeo Incubated Projects, or Projects which are
presented at FOSS4G conferences. If your project is involved in OSGeo
Incubation, or has been selected to be presented at FOSS4G, then please
mention it.
It was presented on different FOSS4Gs and is also in the OSGeo wish list
- Who will act as the project's liaison person.
-Can you please discuss how your application will be installed.
About the installation for both versions, it will use a custom script,
which downloads the files, and then copies them into a directory, from
which is possible to find samples and executables.
-OSGeo-Live is memory and disk constrained. Can the application run in
512 Meg of RAM?
Yes
-How much disk space will be required to install the application and a
suitable example application?
The java version occupies around 300mb with samples, but might be
possible to reduce the size removing some files (documentation ~130mb
). While less than 20mb the Web version
- Each OSGeo-Live application requires a Project Overview available
under a CC By and a Quickstart available under a CC By-SA license.
(You may release under a second license as well). Will you produce this?
Yes
-In past releases, we have included Windows and Mac installers for some
applications. It is likely we won't have space for these in future
releases. However, if there is room, would you be wishing to include
Windows and/or Mac installers?
Yes
Best,
Gabriele
Sent: martedì 5 gennaio 2016 18:13
To: Gabriele Prestifilippo
Hi Gabriele,
Thank you for picking up this task.
For the install script, can you please provide a pull request here:
https://github.com/OSGeo/OSGeoLive/tree/master/bin
Proposed script name: install_worldwind.sh
Also, you can issue a pull request for the documentation here:
https://github.com/OSGeo/OSGeoLive-doc
In order to accept the pull requests, you will need to confirm that you
will comply with our license guidelines:
http://wiki.osgeo.org/wiki/Live_GIS_Disc#Git_migration
Best,
Angelos
Sent: lunedì 4 gennaio 2016 22:53
Cc: live-demo at lists.osgeo.org; Hogan, Patrick (ARC-PX)
Hi Gabriele,
Great to hear from you and interest in seeing NASA WorldWind on OSGeo-Live.
The first step in including a project is to send an email to this list
addressing the questions linked from:
https://wiki.osgeo.org/wiki/Live_GIS_Disc#How_to_add_a_project_to_OSGeoLive
This helps us determine whether a project is a good fit for OSGeo-Live,
and also consider any logistical issues which we might face (such as if
there is enough space).
I'm looking forward to working with you further on this.
Warm regards,
Cameron (one of the OSGeo-Live coordinators)
On 5/01/2016 5:07 am, Gabriele Prestifilippo wrote:
       Dear all,
I'm writing here on behalf of Patrick Hogan's suggestion, to propose
the inclusion of NASA World Wind in the next OSGeo release
(http://goworldwind.org/ and http://webworldwind.org/).
I've been asked to fulfill the requirements from the Wiki, and I
created the scripts for the project and prepared the documentations.
Let me know what else is needed to proceed.
Best regards,
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
Cameron Shorter,
LISAsoft
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
Cameron Shorter,
LISAsoft
OSGeo Charter Memberhttp://users.ntua.gr/tzotsos
Brian M Hamlin
OSGeo California Chapter
blog.light42.com
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160108/05049872/attachment-0001.html>
More information about the Live-demo
