[Live-demo] Review of istSOS Project Overview
Cameron Shorter
cameron.shorter at lisasoft.com
Tue Jan 19 23:25:38 PST 2016
Hi Milan,
I can see you have fixed the images. Thanks.
I'm not sure if you noticed, but I made a number of updates to the text,
primarily providing slight rewording of the English syntax, such that it
aligns with the rest of the OSGeo-Live documentation.
For instance, I had changed your:
"* Offer your data according to the Sensor Observation Service standard
from Open Geospatial Consortium."
to:
"* Publish sensor data in accordance with the Sensor Observation Service (
SOS) standard."
Could you please have a look at the review I provided, and do a "diff"
comparison with your text. Hopefully most of my suggested changes should be
able to be used without changes.
Warm regards, Cameron
On Tue, Jan 19, 2016 at 2:01 AM, Milan Antonovic <milan.antonovic at supsi.ch>
wrote:
> Hi Cameron,
> Thanks for your review. I modified texts and images following your
> comments.
> You will find the modifications in the attachment.
> Best regards
> _Milan
> Il giorno dom 10 gen 2016 alle ore 22:54 Cameron Shorter <
> cameron.shorter at gmail.com> ha scritto:
>> Hi Maxi,
>> I've reviewed your istSOS Project Overview which is attached.
>> Have you put this into git yet? If not, I suggest you do.
>> Overall, it looks to be in pretty good shape.
>> I've tweaked some of the syntax, and made some comments. Look for "..
>> Cameron comment:"
>> My key comment is that the images are too large, which makes the layout
>> look bad.
>> Could you please review my suggestions, and if ok, please include into
>> your git commit.
>> Warm regards,
>> Cameron Shorter
>> On 23/12/2015 11:47 pm, Massimiliano Cannata wrote:
>> Dear Cameron and OSGeo-Live team,
>> in attachemnt you can find the documents required for setting up istSOS
>> in the new Live-demo
>> Please cnsider these as still in draft format, so that required changes
>> can be done in the next future.
>> Best,
>> Maxi
>> 2015-12-19 3:36 GMT+01:00 Cameron Shorter <cameron.shorter at gmail.com>:
>>> Hi Massimiliano and Milan,
>>> If I look at the istSOS OpenHub metrics, it suggests that 95% of the
>>> code is javascript, however the project summary notes the project is
>>> written in Python.
>>> Would I be right in suspecting that your OpenHub entry is not accurately
>>> pointing at your source code?
>>> If so, could you please update OpenHub such that the metrics are more
>>> accurate.
>>> We encourage people to assess the quality of a project by looking at
>>> Open Hub metrics [2]
>>> [1] https://www.openhub.net/p/istsos
>>> [2] http://live.osgeo.org/en/metrics.html
>>> On 18/12/2015 8:33 am, Cameron Shorter wrote:
>>> Seems my last email was too big for the email list, here is the trimmed
>>> version:
>>> On 18/12/2015 8:18 am, Cameron Shorter wrote:
>>> Hi Massimiliano,
>>> We discussed including istSOS on OSGeo-Live in our weekly meeting today,
>>> and all present were in favour of it being included. So welcome to the
>>> OSGeo-Live community.
>>> Could you please focus first on working out your install process so that
>>> we can get istSOS into OSGeo-Live builds and start testing it.
>>> Then start working on the Project Overview and Quickstart.
>>> Could you also please start an email thread suggesting what dataset(s)
>>> should be used for istSOS.
>>> I suspect that your dataset needs would be similar to 52 North SOS?
>>> There may be other datasets on OSGeo-Live which might be of use too?
>>> Ideally we'd like to ensure we use the same datasets across applications
>>> On 17/12/2015 7:52 pm, Massimiliano Cannata wrote:
>>> Dear Cameron, sear OSGeo-live team,
>>> here below you can find the istSOS application ofr being included in
>>> the next OSGeo live release.
>>> Cameron Shorter,
>>> Software and Data Solutions Manager
>>> LISAsoft
>>> Suite 112, Jones Bay Wharf,
>>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>>> P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
>>> Cameron Shorter,
>>> LISAsoft
>> *Massimiliano Cannata*
>> Professore SUPSI in ingegneria Geomatica
>> Responsabile settore Geomatica
>> Istituto scienze della Terra
>> Dipartimento ambiente costruzione e design
>> Scuola universitaria professionale della Svizzera italiana
>> Campus Trevano, CH - 6952 Canobbio
>> Tel. +41 (0)58 666 62 14
>> Fax +41 (0)58 666 62 09
>> <massimiliano.cannata at supsi.ch>massimiliano.cannata at supsi.ch
>> *www.supsi.ch/ist <http://www.supsi.ch/ist>*
>> Cameron Shorter,
>> LISAsoft
Cameron Shorter,
LISAsoft
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20160120/e804f162/attachment.html>
More information about the Live-demo
